I have a 1971 Mk11 saloon, fitted with standard road springs (old), standard insulators, and potentially (can\'t get the caps off to see yet) koni damper inserts - although these may just be standard or heavy duty items. The problem I have is that the front wheels appear to have a little positive camber, i.e. they appear to lean out slightly at the top. I have renewed all the bushes etc and everything is bolted together properly. Is this normal ?? I can\'t tell if it was like this before I did any work as the suspension was in a bit of a mess to say the least.The car is running a set of period Cosmic alloys with 185/70/13 tyres. The only other mod that may effect the suspension height is that the battery is located in the boot, but surely that will not make a significant difference ?
Biff
Front Suspension Camber
