Strut brace
I've been following your strut brace manufacture with interest, thinking possibly doing something similar.Freight costs would prohibit my getting one of yours.
By coincidence I've just got a copy of "The BMC/BL Competitions Department" by Bill Price.
At this time I've only skimmed through it, its 390pages long, but if anyone can get hold of a copy have a look at page 255, A picture of mk2 P.I. 1970 World Cup Rally car. it shows a brace. Looking with a glass, it shows the brace bar bolted to the plates on top of the towers.
Thought it may be of interest.
Re: Strut brace
Interesting,
If anyone has a copy can they scan and post the picture?
1977 2500s Saloon
Re: Strut brace
I don't know how clear this will be but here goes.Sorry image too big .will reduce tonight when I get home from work.
Scan was not very clear, have taken a couple of pictures which look a bit better.
Re: Strut brace
Mikeyb
Had to reduce resolution to get these accepled.
If you like ,if you give me email details ai'll send you better ones
Tony
Tony
Re: Strut brace
Thats interesting indeed!
Unboltable. You still need to undo 4 bolts tho, and I can undo all 6 strut top nuts in about 2 mins. But i suppose every second counts in competition.
Also would having the bolts through like that make the whole structure weaker and not aid stiffness as much as a welded one?
With a bit more thought and design I could probably have some of these type made, althougth the extra fabrication involved would increase the cost.
The other possibility is that I can make the bits that go onto the strut tops and leave it up to you (the public in general) to make your own bar to fit between how you want it.
I still think my design is neater and more pleasing to the eye tho
1977 2500s Saloon
Re: Strut brace
If you look closely at the brace bar, which appears to be 1'' square tube, it seems to be reinforced each side of the rocker cover. I wonder why.
Re: Strut brace
It actually looks like it is made up of three peices welded together as in an earlier design on this thread
____-----____ like this?
1977 2500s Saloon
Re: Strut brace
Hello Tony,
what I think it is that the tube is in three pieces with the centre section welded on top of the outer pieces to clear the rocker cover. All in all it doesn't look like a very well designed or fabricated item. Very clumsily done in my view and not exceptionally strong either.
Re: Strut brace
Alec wrote:Hello Tony,
Snapmikeyb wrote:It actually looks like it is made up of three peices welded together as in an earlier design on this thread
1977 2500s Saloon
Re: Strut brace
The question has to be asked - what are those pipes going past? Air for something?
