Strut brace
Hello allen,
not ideal, but probably as good as you will get given the 2000's engine height - low bonnet line.
I assume that is a sketch as ideally the strut plates need more gusseting to the tube, as drawn it is very weak there.
Re: Strut brace
just to give the general idea i think
1977 2500s Saloon
- Allen Walker
Re: Strut brace
Yes, the sketch is completely from memory, I'm sure there's adequate bracing on the real thing. It was just to show the concept of having the central tube which clears the rocker cover, and two shorter lengths of the same tube welded underneath. Saves having to bend a tube, relatively easy for the home welder to fabricate, I'd have thought.
Allen Walker
Hoole, Chester[/size]
Re: Strut brace
Mine was made by our ex-chairman Dave Tattersall...........
Re: Strut brace
Just out of interest, if I was to get a batch made how many of you would be interested and what sort of money would you like to pay?
I can have them made in Alloy for extra cost.
They will come in primer or for extra cost top coated.
Can be chromed for extra cost.
Costs can be reduced if you dont mind drilling your own holes
Mike
Mike
1977 2500s Saloon
- Allen Walker
Re: Strut brace
Well, to turn the question around:
What would it cost to make 10 in alloy?
Allen Walker
Re: Strut brace
Alloy would also not need coating/painting, and is relatively easy to drill your own holes inAllen Walker wrote:Well, to turn the question around:
Yes how much for each scenario mentioned?
Re: Strut brace
One more question I need answering before I give my man the details, do you want round tube, bent to fit, or square tube, cut and welded to fit?
Ta
Ta
1977 2500s Saloon
- Allen Walker
Re: Strut brace
I really don't know. I'd want it to perform properly but looks are important. Who would know which method is best?mikeyb wrote:do you want round tube, bent to fit, or square tube, cut and welded to fit?
Allen Walker
Re: Strut brace
I would have thought it should be as straight as possible? What you are trying to achieve is resistance to the strut tops moving inwards/outwards. This force is likely to be a shock force I'd have thought, and a bent brace is more likely to deflect that a straight, welded one. Wouldn't it?
Again, for the same reason would steel be better than alloy? Mind you that's not taking into account any under bonnet 'bling' effect! If it comes primed, I can always give it some colour top coat.
