Good day to all,
I dont know and I can not figure out why I got gasifyed
while driving. Its horrible.....
I got a new exhaust (standart)from Rimmer (it is sealed and tight) !!
I checked the bootseals (left a blanked in the trunk while
driving) but no gassmell !!
Allmost no difference if Window open of not (might be a little
worse when window open - but are 2500 Pi drivers not allowed
to open window while driving ??
Manifold is thight too, no gas form enginebay while standing.
Any idea ?
B/R, Marco
HELP-Gasifying trough Pi Lady
Re: HELP-Gasifying trough Pi Lady
Hi,
Do you mean you got an overpowering petrol smell in the car, or you had exhaust fumes entering the car?
If petrol I would check all your connections in the engine bay, althougth if theres a leak in the boot it can still be smelt.
Exhaust gasses in the car, and getting worse with window open suggest that you must have either an iffy seal on part of your exhaust near the engine or perhaps you have a cracked manifold??
Just reading your post again, it could be your manifold needs a new gasket.
If it is worse when the window is open then check the rubber gear lever boot (under the black trim)
when this goes (or is not fitted right) with a window open it draws fumes up from the engine/gearbox area into the car.
On a PI, if it a petrol smell, usually a sign of the fuel pump main rear seal needing replacing.
Or where the sender unit is fitted in the side of the petrol tank, remove the rear upright boot trim to check this.Alan Chatterton wrote: On a PI, if it a petrol smell, usually a sign of the fuel pump main rear seal needing replacing.
Or pin holed petrol tank leaks...............I had this on my mk1 pi and petrol smell was horrible and used give me an headache.As stated the holes in the tank were pin holes but were enough to release fumes
- renegade53
my petrol fumes come from the fuel that leaks badly from the filler cap. suspected damage to the bit of pipe the cap goes onto
mk1 2000 estate
91 toyota corolla
http://renegade53.t15.org/
http://www.ipernity.com/home/287293
http://www.youtube.com/user/2000outlaws
91 toyota corolla
Hi Marco,
You need to decide on what the smell is - petrol, exhaust or something else. If the problem started when the new exhaust was fitted that might be a clue.
If the smell is exhaust then maybe the manifold joint was distrurbed - as already suggested.
If the smell is neither petrol or exhaust then it could be that it's coming from the new exhaust - paint burning off or WHY. Alan's suggestion of the gearlever boot may be the cause. Before the new exhaust you didn't notice as it was letting in fresh air. Maybe now it's letting in the new exhaust smell.
hi mate,
have a look make sure the breather pipe hasn't come off the rocker cover.
steve.
steve.
2 stags,2 tr6's,2 gt6's(all gone now) onto my 3rd mk2, i need all the help i can get
