outer front door handles
sahtuning2000
#1 Post by sahtuning2000 » Sun May 26, 2019 6:21 pm
What is the difference between mk1 and mk2 front outer door handles?
Rears I think are the same.
Re: outer front door handles
#2 Post by johnnydog » Sun May 26, 2019 11:27 pm
The main part of the handle is the same, but the lock is different. The lock, I believe, can be swapped over between the two. The Mk2 has lot deeper lock with the key being much longer.
The rears are the same as you say.
sahtuning2000
#3 Post by sahtuning2000 » Mon May 27, 2019 8:23 am
The handles I,ve been offered have no locks/keys and are unbagged but NOS,is there a danger that the MK1 lock won,t fit them at all or is it a case that the MK2 lock with the larger key was more sturdy but used the identical handle?
#4 Post by johnnydog » Mon May 27, 2019 1:45 pm
CW lists Mk2 front door handles with the lock and keys, and also bare / without.
There is no reference to Mk1 door handles.
I can only presume then that exterior front door handles, although they look the same, are actually different where the key / lock fits. He normally states in his listings if parts are suitable for both Mk1 and Mk2.
