Heater Valve
Sloppy 2000
Heater Valve
#1 Post by Sloppy 2000 » Sat Apr 07, 2018 3:05 pm
Sadly, after a really nice run in the warm sunshine, I found on my return that the heater valve was leaking.
Does anyone know which are compatible?
I have found this for about £34 https://www.ebay.co.uk/itm/JAGUAR-MK2-V ... XQya1Q7KFX
However there are a few which look exactly the same for much less. Does any one have a part number or suggestion?. Jeff
Triumph 2000 estate mk1 1968
Re: Heater Valve
#2 Post by johnnydog » Sat Apr 07, 2018 8:57 pm
Hi Jeff,
The Triumph part number for the water valve is 570230.
The one in the link looks the same but without comparing it with an original, I can't say with 100% accuracy.
I can check Sunday morning to see if I have an original spare to compare with the new one in the link, or if I have one, whether a used one is any use to you.
John.
Re: Heater Valve
#3 Post by Alec » Sun Apr 08, 2018 7:48 am
Hello Jeff,
The Jaguar MK 2 does use a valve that is very similar to the Triumph Mk 1. However I note the seller is Ashley Hinton who trades in heaters and accessories amongst other things so I suggest that he probably is correct in saying it fits the Triumh.http://www.mg-cars.org.uk/ah/index.htm.
I bought one earlier this year but from Chris Witor, and I know he charges a deposit until you send back your old unit so he can restore the steel bits and reuse them.
Jaguar X Type Estate 2.5
englishbull
Re: Heater Valve
#4 Post by englishbull » Mon Apr 09, 2018 10:59 am
the on in the link is correct.
Fitted one to my MK1
No Pi's in my garages
1985 MG Maestro in Silver
1962 Triumph Tina Scooter Red
Peter Douglas W
Re: Heater Valve
#5 Post by Peter Douglas W » Tue Apr 10, 2018 10:28 am
I don*t understand. If Triumph tried to use common parts, why are we going to MG or Jaguar or or to get a valve which is standard on the TR series? The TRs have the same engine, so why should they have another valve? I am not talking about quality. :? :? :?
Peter Douglas Winn
A happy Triumph owner.
Sloppy 2000
Re: Heater Valve
#6 Post by Sloppy 2000 » Wed Apr 11, 2018 10:15 pm
Hi Thanks all,
I think that it was originally a LUCAS part and hence the interchangeability, just guessing, wouldn't stake my life on it or anything
Jeff
Sloppy 2000
Re: Heater Valve
#7 Post by Sloppy 2000 » Wed Apr 11, 2018 10:23 pm
Just as well I didn't stake my life on it, Smiths not LUCAS
