I have decided to try and sell this panel as I don't want to fit it on my car. It was supplied by Lloyd Reed and apart from cleaning the rust off, it is as supplied. It was described as being a half wing but was made 1 1/2 inches taller than standard so if you need a larger repair panel but not a full wing this might be of use. There are a few areas I could describe as faults but I have been assured they are to be expected with a hand made panel.
I have been told these are made by the same company that makes some of the Heritage panels so should fit OK.
This might be the last of these available as Lloyd is considering not supplying any more panels.
Please ask on here if you are interested or want any more details, thanks for looking.
I'm in Andover, Hampshire.
£350.
