Exhaust manifold beast, what other adjsutments?
Posted: Mon May 26, 2014 1:39 pm
by christopherhenry
I've obtained a beast of a 6 - 1 exhaust manifold for my Mk2 2000. I believe it's a TR6 manifold, but it may not be standard even for a TR6. It has 6 separate pipes that all come together to a single rather large pipe which splits into 2 for a twin exhaust. Fortunately as the car is a LHD, I have plenty of room on the right side of the engine. I think the steering would get in the way on a RHD.
We're going to fit the manifold and a custom exhaust system to the 2000 this week. My mechanic/friend in Germany that will be doing it has obtained some pipe which is about the same diameter as the output of the manifold (there isn't room for a twin exhaust, so we're sticking to a larger bore single) and also a couple of silencer boxes, a short one for the middle and one for the back, under the boot. The standard pea-shooter exhaust has a few minor holes and problems, so needs to be replaced anyway. The aim is for a few more BHP and of course a better exhaust note.
I think he's intending to come straight down with the manifold and then straight back, so not going through the chassis, as the standard exhaust seems to do in 2 places. It'll come out on the left where the existing exhaust goes. Ground clearance will be reduced, but apart from that I can't see it being much of an issue.
Is there anything we need to be aware of? Does anyone have any tips or pointers? What about carb (Stromberg) setup afterwards? Will I need richer needles or to make any other adjustments elsewhere? What about the extra heat, should we take measures to shield the manifold or wrap it in something?
Thanks.
Re: Exhaust manifold beast, what other adjsutments?
Posted: Mon May 26, 2014 2:41 pm
by red2000chris
HI. I would wrap the manifold in heat wrap as there will be a lot more hot surface area under the bonnet. As for the other possible issues, I would wait for more people in the know to comment but I guess there will be a big drop in back pressure for the engine and carbs to remain in standard tune. :D
Posted: Mon May 26, 2014 2:53 pm
by christopherhenry
Can't do any harm to wrap it in heatwrap can it!
Posted: Tue May 27, 2014 12:40 pm
by TRPi
@christopherhenry, thanks for notifying in similar thread: viewtopic.php?f=11&t=4910
As told by others, many would prefer 6-3-1 against 6-2-1 and 6-1 design. In Peter Collier's Triumphant Rallying book - "steel tubing exhaust manifold, 55mm outlet" - is mentioned about Triumph 2000 mk1 group 3 FIA spec. I would guess, that Standard-Triumph used 6-2-1 spec for rallying big saloons (when allowed by rules).
I have no practical experience on this topic, but I would assume loss of low-rev torque with 6-1 design.
If I am not wrong, 2.5Pi works rally cars had exhaust system running out of car's right side near rear door. Obviously it had only one silencer below the front seat on RH :)
JS
Posted: Tue May 27, 2014 2:03 pm
by christopherhenry
Thanks. I've answered in the other thread, we may as well keep it all in there.
