Aftermarket tachmoeter/rev counter
SimonO
#1 Post by SimonO » Mon May 12, 2014 6:35 am
I have a PFL Mk2 without a rev counter - but would like to install one.
I am considering either swapping the dash for a later 2500 one or putting an aftermarket rev counter (pod thing) on the dash.
Anyone recommend/used an aftermarket unit???
englishbull
Re: Aftermarket tachmoeter/rev counter
#2 Post by englishbull » Mon May 12, 2014 11:35 am
See how Dave Harvey as fitted his new rev counter into existing dash bezel
No Pi's in my garages
1985 MG Maestro in Silver
1962 Triumph Tina Scooter Red
#3 Post by Dave B » Mon May 12, 2014 6:17 pm
If you can get a PFL 2500 dash, that would be the easier way, as everything springs to life as it should without any wiring harness mods, all the necessary wiring is already installed.
Toyota Avensis TR
red2000chris
#4 Post by red2000chris » Tue May 13, 2014 4:59 pm
have you got a radio or just the plastic panel? I haven't got a radio so I used a TIM rev counter and oil gauge and fitted them in the plastic panel.
#5 Post by Dave B » Tue May 13, 2014 6:42 pm
red2000chris wrote:fitted them in the plastic panel.
Bit out of line of sight there. Mind you don't run up someone's chuff whilst checking your oil pressure :wink:
Toyota Avensis TR
SimonO
#6 Post by SimonO » Sun May 18, 2014 8:03 am
I like Dave B's suggestion of fitting a PFL 2500 dash. Can they be easily distinguished - loads come up on eBay but I never know what they are! :(
CAR
#7 Post by CAR » Sun May 18, 2014 10:04 pm
SimonO wrote:I like Dave B's suggestion of fitting a PFL 2500 dash. Can they be easily distinguished - loads come up on eBay but I never know what they are! :(
Pointed sword shaped needles, black bezels and a chrome 'button' in the centre of the dial. fl dials have square needles and black bezels with a chrome outer edge. The dash will also have a rheostat for the dial illumination on pfl, fl has a rectangular seatbelt warning light and hazard warning light switch.
SimonO
#8 Post by SimonO » Tue May 20, 2014 8:45 am
Thanks!
The hunt begins... :)
SimonO
#9 Post by SimonO » Tue Oct 16, 2018 12:31 pm
Only four years later...
I have fitted a PFL Mk2 PI dash into my 1972 2000 - just in time for the RBRR.
However the one on the dash doesn't work correctly. I believe it's due to me having the 123 electronic ignition fitted and my rev counter is the RVI type.
Can anyone recommend a place to convert my current dial to RVC, or is there a "plug-in and play" alternative (I would like the dials to match if possible)
I realise that the wiring will need to be converted too....
sprint95m
#10 Post by sprint95m » Tue Oct 16, 2018 1:12 pm
Your tachmoeter is connected to the ignition coil's positive terminal?
I got one of these to work on a Dolomite with 123 ignition, with the existing wiring, by bypassing the ballast resistor
and then running a new separate feed to the 123 distributor (from the fusebox inlet side).
(on a standard early Dolomite a tachometer failure results in no ignition,
doing the above means that should such a tachometer failure occur the car will still run.)
Ian.
PS I saw your car at John o' Groats on the RBRR!
