It is currently Fri Sep 03, 2010 3:22 pm
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Heater return pipe (behind exhaust manifold)
PostPosted: Wed Jul 28, 2010 1:06 pm
Offline
Ever since I've had the car, it's had some minor incontinence (dampnes on the garage floor only), thought to be from a rubber hose. On the way back from the National, it got a little worse, but far from terminal.
Deciding investigate and give the car a clearly needed flush out made maters worse and I now reckon there's a pin hole in the pipe (TKC 2045) near the back, above the starter motor. The question is how do I disconnect it from the back of the water pump and get it out to inspect / replace? The pipe appears to be stuck in the nut (101302) and I don't want to break anything!
_________________
David Brewster (Memb 3937)
Edinburgh
2500S in White, with blue cloth interior. Manual Overdrive
2500S in Rus(se)t Brown with beige cloth interior. Manual Overdrive, but originally auto
Top
 Profile
 Post subject: Re: Heater return pipe (behind exhaust manifold)
PostPosted: Wed Jul 28, 2010 2:09 pm
Offline
Without looking at a car, am I correct in thinking that removing the water pump housing from the engine, would allow you to inspect this problem a lot better?
If this is the case, looking at it on the bench and from all angles is certainly easier than trying to wrestle with it whilst leaning into the engine bay and working around other ancilliaries, using a lead light.
It may seem like a lot of work, but it may be easier in the long run.
Does CW do a stainless replacement for this pipe?
_________________
Colin R and Amanda J
'75'N' 2500S ESTATE IN CARMINE. France Easter'09
'71'J' 2.5PI SALOON IN VALENCIA.France Easter'10, WCR40 and Stoneleigh 'showcar'
Top
 Profile
PostPosted: Wed Jul 28, 2010 5:51 pm
Offline
Hello David,
there are two hexagons where the pipe enters the water pump, one (larger) is the adapter that screws into the water pump and cannot be unscrewed without removing the pipe. You need to unscrew the smaller of the two, this is a compression fitting with an olive on the pipe.
These pipe do rust through and I suggest you get a new pipe (and olive) prior to trying to dismantle it as it may well be damaged further in the removal process.
_________________
Top
 Profile
PostPosted: Wed Jul 28, 2010 8:24 pm
Offline
WD40 the two unions that screw into the rear of the water pump housing. Spanner them back and forth - maybe they will work loose. My leak in that spot was years ago, whilst on a stage rally. It appeared to be the pipe which I thought I could tape up. It actually was the core plug !! A piece of internal iron had rusted a pin hole ..... how does one fix that in 5 minutes ? Self tapping screw and exhaust paste. Maybe its possible to unbolt the waterpump and turn the whole thing anticlockwise to undo the larger nut. OR saw through the pipe to remove, and solder a repair piece.
_________________
Steve Knight
Top
 Profile
PostPosted: Wed Jul 28, 2010 8:48 pm
Offline
your profile states that both your cars are S models .. on these, due to the shape / fixings, I have never successfully removed that pipe, without removing the exhaust manifold, pulling it back from the head and extracating the pipe upwards ... and they always rust out .. and Chris Witor DOES do a stainless steel version .. specify that it is for an S model .. or it will be without the "T" piece which feeds into the inlet manifold .. removing the exhaust manifold is ALOT easier with the bonnet off .... GOOD LUCK !! Andy Harrison ... and you were looking for a quick fix ?? !!.....
Top
 Profile
PostPosted: Wed Jul 28, 2010 9:40 pm
Offline
Thanks for your collected wisdom. I'm getting the message that trying to get the pipe out in one pice may be well nigh impossible, so I very much suspect its a hacksaw and call to Mr Witor.
Being a good Scot, I will have one final go a seprating the unions first, though...
Thanks. Much appreciated
_________________
Edinburgh
Top
 Profile
PostPosted: Wed Jul 28, 2010 10:06 pm
Offline
Hello David,
one little point, Steve recommended WD40, Plus Gas is much better for that application, but if it has a pinhole it will probably be weak so don't be too enthusiastic with the spanners.
_________________
Top
 Profile
PostPosted: Thu Jul 29, 2010 6:19 am
Offline
You say leak is at the firewall end so probably at the tee piece, not that it really matters :(
Experence tells me that the exhaust manifold will have to be unbolted from the head and pulled clear to allow the pipe to come out.
The union nut should undo with a bit of work.Seem to remember I ground an old open end spanner to be a tight fit and used a pair of visegrips to hold the larger fitting nearest the water pump.
The best of British luck to you Sir !
_________________
1976 2500 TC
1978 2500 S
1990 Peugeot 405
If all else fails.....read the instructions!!!
Top
 Profile
PostPosted: Sun Aug 08, 2010 8:17 pm
Offline
Hi Andy,
Um, why? Leaning in from the front?
_________________
1967 Herald 1200 Convertible rust should be white
1970 2000 Saloon Sienna
1972 Stag French blue
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
