fitting a diff drain plug
Rod 2500S
#1 Post by Rod 2500S » Wed Sep 04, 2019 7:06 am
Gday
Has anybody fitted a drain plug to their diff? if so any feedback as to a good position for this would be appreciated
cheers all
Re: fitting a diff drain plug
#2 Post by Dave B » Wed Sep 04, 2019 8:35 am
#3 Post by johnnydog » Wed Sep 04, 2019 9:57 am
I have 2.5 diff that has a drain plug fitted. It isn't on a car, but buried on the garage, so I can check it when I can get to it if required to confirm where the drain plug has been positioned.
#4 Post by Alec » Thu Sep 05, 2019 5:54 am
Hello Rod,
I drilled and tapped a hole in the base of the casing while I was rebuilding my differential.
Straightforward when it's out of the car.
Rod 2500S
#5 Post by Rod 2500S » Mon Sep 16, 2019 1:38 am
thanks gents
there's a "boss" thingy on the bottom of the case close to the back edge where the rear case bolts on, looks like it was intended for a drain plug. I'm going to drill and tap this.
Rod 2500S
#6 Post by Rod 2500S » Wed Dec 04, 2019 5:24 am
hi all
done see pic
Used a SS 3/8th UNC Cap screw (because I had one laying around)
The hole is chamfered to accept an O-ring under the bolt head and the wire hanging down is to secure the bolt when i finally finish the job
cheers all
Rod
