Mk1 Pi engine rebuild
M5driver
Re: Mk1 Pi engine rebuild
#11 Post by M5driver » Fri Mar 15, 2019 4:40 pm
Pictures
They keep disappearing!!!!!!!
The attachment P1030289.JPG is no longer available
Chris Lennard Mem 1906
VW Golf mk6 Bluemotion Black
Carboy0
#12 Post by Carboy0 » Fri Mar 15, 2019 7:57 pm
Are they valve spring collets, or part of the Oil pump?
#13 Post by johnnydog » Fri Mar 15, 2019 9:17 pm
You'd be surprised what you find in the sump. When I put a magnetic drain plug in the sump of my S, at the next oil change, attached to the drain plug was a tapered cross head machine screw like the one located in the pedestal of the rocker shaft. Fortunately, when I removed the rocker cover, there was still one there. I can only assume that the one in the sump had been there since manufacture. Can't think of any other way it got there!
M5driver
#14 Post by M5driver » Sun Mar 17, 2019 6:03 pm
Well looking at the offending item it appears to be made of alloy where it came from don't know. The oil pump is intact if a little worn, the rotors being out of tolerance. I expected this the oil pressure was low when hot.
The attachment P1030292.JPG is no longer available
The Pistons and rods are now out at some point a little dirt got to the bearings and all of the crank journals for the rods are slightly scored so a regrind looks like its on the cards. The mains look ok so far I sill have three to uncover.
Also removed is the front sealing block. I have a stainless replacement to go in from Jigsaw racing. The front engine plate removes as well. Crank end float was checked and just over tolerance so new thrusts should suffice. The piston rings are very worn no wonder oil consumption was on the high side, the oil control rings being particularly bad. So the shopping list has grown and the predicted machining costs have gone up. Back to work tomorrow so progress will come to a halt for a while.
