Distributor Rebuild query
I am rebuilding a 2500S 45D6 distributor that I picked up at Stoneleigh the other week. It’s come apart fairly well and there is negligible wear on the shaft or the housing, so it’s good to go again.
I need to replace the O ring on the housing, can anyone advise the part number and a source, or alternatively the size (imperial).
The usually very helpful Rimmers website doesn’t list the part.
Thanks in advance.
Thanks in advance.
Re: Distributor Rebuild query
According to the parts book, it is 513862.
Chris Witor is usually the best source of both info and parts for our Triumphs. I haven't bought anything from Rimmers for years........
- herald1360
Distributor Doctor would be able to supply any parts you need, all good quality
Regards
Regards
Paul Barlow
Exeter
1974 2500TC French blue
Exeter
Thanks Guys, I have emailed the DD.
I don’t generally use Rimmers for parts, but their online parts catalogue is normally great for identifying part numbers etc.
Can you confirm the part number, I can find 513682, but not 513862.
Sorry, a slip of the digit (!), it is 513682 - my apologies!!
Hello Carboy0,
did you check the number stamped on the distributor to verify it is correct for your engine?
Hi Alec,
Yes thanks, checked and cross-checked.
The Distributor Doctor has sorted me out the correct £0.75 ‘O’ ring.
