Front windscreen
Hi all looking to fit the front windscreen to my 2000. I have fitted a few windscreens in the dim distant past so think I know what I’m doing if I haven’t forgotten it all
Anyway I’ve got a new windscreen and a new windscreen rubber what I’m wondering is about the “chrome” trim. I seem to recall fitting that trim is a tricky job...
So do I fit the trim to the rubber BEFORE I fit the windscreen or do I fit the windscreen then try to get the trim on?
Words of experience gratefully received.
Re: Front windscreen
Old post but if don’t want to make the tool you can put the trim on first, which is favoured by others but I’ve personally never tried it. The workshop manual has the dimensions for the tool
It is tricky you get so far and the lip decides it want to release the trim further back from where you came from and the you have to start again, as you can’t drag the tool backwards to insert it again. Best to have a second pair of hands to hold the trim down which has been coaxed in the lip. Silicon grease helps the tool slide round.
This has been discussed previously, but relatively local to our Group, there is a windscreen fitter who specialises in classic car windscreen fitting. He has done members Triumphs windscreens in Lancashire and does a good job. I have a leaky windscreen in one of my Triumphs and will definitely be using him to either reseal the original or fit a replacement as necessary.
The gist of the above is that this chap fits the trim first, and I have seen some of his work on our cars, and it is very good.
Cheap reproduction windscreen seals appear to be made of a softer rubber compound than genuine original seals, and are more prone to being deformed through bad fitting.
The points for me that indicate a good windscreen fitting on the Triumph 2000 is whether the trim sits properly at the bottom corners and/or whether copious amounts of sealant have been used between the seal and the body. Besides looking sh*t, excessive sealant is unnecessary if the screen is fitted properly.
I'll check the workshop manual tonight for the tool dimensions. You know I cannot recall when i did this last if i put the chrome on first or gave up trying to fit it (if would have been about 30 years ago!) might have to see if I can find a picture of the car.......
Hello Jake here are some pictures of some service notes explaining the procedure with the tool:
- Triumph Windscreen Training Notes:
- Photograph Link: https://photos.app.goo.gl/MxnR9wJoXDZJfwSc8
Last edited by Tinsmith_Skippy on Sat Nov 28, 2020 5:02 pm, edited 10 times in total.
I'll think on the screen fitting, the headlining is "mostly" done, fitted around the front screen, and along the top of the 2 front doors. Hopefully finish it off at the weekend... I'll post it on the Headlining chain then.
Had one good idea after your comment on finding the holes after fitting the headlining, taped a sheet of A4 to the roof then folded it over the screen lip and marked the existing fixings on it. Then folded the paper up out of the way while I fitted the headlining. Once I'd fitted the front of the Headlining I just folded the paper back out and stuck a scribe though the paper and headlining. All lined up great.
Good idea on the hole finding, definitely going to use that tip on the next headliner! Might be a while, still recovering from the last one!
- Window Trim Installation -
Last edited by Tinsmith_Skippy on Fri May 03, 2019 9:18 am, edited 6 times in total.
Nice one!
My only comment would be to suggest that next time(!) the camera is rotated 90 degrees (ie landscape).
Nice video guys, you make it look quite possible, I wonder how long it really took but suspect the time is not the problem, technique is. I'll let you know how I get on.
