Mk1 Pi engine rebuild
M5driver
#1 Post by M5driver » Thu Jan 03, 2019 9:20 pm
After many years of service the original engine for my Mk1 Pi is out for a rebuild. The reason being it was rather smokey and leaking oil and probably down on power.So far the rocker shaft has been removed and dismantled.
The attachment P1030172.JPG is no longer available
If you can see most of the flats for the oil feed holes have worn away. So this needs replacing. After wiping the shaft down there were also some ridges where the rockers ran . Also all of the rockers themselves are wearing through the hardened surface. these will also be replaced.
All the head nuts have been removed and in the process two of the studs came out as well. As far as I am aware this head has never been off since Triumph put it together. I have had a look at the push rods and the face bearing against the follower has worn equally I must say they are not bad for an engine that has covered around 115000 miles.
The next job is to get the head off the block and assess the state of the valves, seats and guides. When this has been done I can then get the reminder of the engine on the stand for the rest of the disassembly.
The attachment P1030170.JPG is no longer available
Chris Lennard Mem 1906
VW Golf mk6 Bluemotion Black
Tinsmith_Skippy
Re: Mk1 Pi engine rebuild
#2 Post by Tinsmith_Skippy » Fri Jan 04, 2019 5:27 pm
Hello Chris happy new year to you. Looking forward to reading future posts on your engine rebuild. I’m going to have to rebuild my Pi engine as wel. It was well seized up, had to knock 3 seized pistons out off the block. Probably going to be a rebore than a honing procedure due to rust pitting in the liners. All the best.
Ross Taylor & Paul Taylor
M5driver
#3 Post by M5driver » Sun Jan 13, 2019 8:16 pm
<r>The head has been removed with much heaving and hoeing. My back doesn't like it. But it came off without too much brute force. The valves and springs have been removed have been removed. I have checked the valve stem movement in the guide. All the exhausts move excessively the inlets are not so bad. But all will be replaced I think.<br/>
<ATTACHMENT filename="P1030184.JPG" index="0"><s>
</s>P1030184.JPG<e>
</e></ATTACHMENT>
All a bit rich but the car was being moved around the yard when the engine was last run.<br/>
<br/>
All the valves out the usual carbon build up.<br/>
<ATTACHMENT filename="P1030190.JPG" index="2"><s>
</s>P1030190.JPG<e>
</e></ATTACHMENT>
Here is a closer shot. Not bad considering its the first time apart.<br/>
<ATTACHMENT filename="P1030192.JPG" index="2"><s>
</s>P1030192.JPG<e>
</e></ATTACHMENT>
Finally a shot of the bores not a great one the lighting is not the best.<br/>
<ATTACHMENT filename="P1030187.JPG" index="1"><s>
</s>P1030187.JPG<e>
</e></ATTACHMENT>
The next task is to get the engine onto my stand. A crane is required and I may have to borrow one. Have a busy week at work so not much can be done now for the next 6 days.</r>
M5driver
#4 Post by M5driver » Sun Jan 13, 2019 8:19 pm
Sorry the pictures did not load up. Damn computers.
The attachment P1030184.JPG is no longer available
The attachment P1030186.JPG is no longer available
The attachment P1030190.JPG is no longer available
M5driver
#5 Post by M5driver » Wed Jan 23, 2019 1:01 pm
Well have tried editing the posts to put the pictures back in no luck I can only seem to post one per reply.
Anyway now the timing gear is off cam and followers out. No signs of wear to the cam or followers. the timing chain is worn so is the tensioner, also the crank sleeve was turned around due to being scored by the oil seal. I have seen this many times in the past, so will be replaced.
Anyway here is a pic of the worn rockers again.
