Air filter elements SU
Phil T
#1 Post by Phil T » Wed Jan 02, 2019 12:56 pm
Hi All
Anyone know where I can get the elements for my 2000 air filter for HS4s?
The likely suspects are all out of stock.
Re: Air filter elements SU
#2 Post by johnnydog » Wed Jan 02, 2019 4:02 pm
I'm not promising anything, but I may have some.....
I can check if I have any and let you tomorrow evening if that is any good to you?
Phil T
#3 Post by Phil T » Wed Jan 02, 2019 6:45 pm
That would be great, thanks.
#4 Post by johnnydog » Thu Jan 03, 2019 11:43 pm
After possibly getting your hopes up, I have checked all my air filters - I have plenty of the Stromberg type, but unfortunately no HS4 types. I did sell two sets last year as I don't have a car that uses them, but these must have been the last ones I had . Sorry!
#5 Post by johnnydog » Thu Jan 03, 2019 11:48 pm
A quick search on Ebay shows one listed for sale ( I appreciate you need two!) - item no 253815952653
Or even better still a pair of TJ filters - item no 223274747518.
Or another pair - item no 223274717700.
Loads available!!
#6 Post by tony » Fri Jan 04, 2019 3:05 am
Or you could fit a pair of K & N's :shock:
Phil T
#7 Post by Phil T » Fri Jan 04, 2019 8:46 pm
True, I could fit K&Ns, but cost is a factor at the moment.
Phil T
#8 Post by Phil T » Fri Jan 04, 2019 8:47 pm
Thanks for looking.
#9 Post by johnnydog » Fri Jan 04, 2019 10:47 pm
I take it you saw my post regarding the ones available on Ebay?
Although it is personal preference, I am a stickler for originality, and as such wouldn't consider K & N filters.
There's nothing wrong with original filters as long as they are clean. With the mileage the majority of our Triumph do these days, and the UK enviroment, a replacement set should last for a reasonable length of time!
