On a 1977 2500S. Easy or difficult?
Mine's cracked quite badly around the choke knob but I have a better one to swap in. Hoping to get it done tomorrow but the manual is pretty vague on this task - hopefully it means it's nice and easy
Presumably the fan switch and cigarette lighter need to come out, along with the choke knob and cable?
Anything I need to watch out for?
Centre console removal
1977 2500S - White
1977 2500S - White
Re: Centre console removal
Pretty straight forward, just a bit of a bind removing the knobs. Also the set screws have been in a long time and I have had some completely seized into the floor pan.
What's the best way to remove the knobs?
1977 2500S - White
1977 2500S - White
IIRC there is a spring-loaded plunger on the underside of the spindle of the fan switch knob, and some, but not all, of the choke cable knobs. Just depress the plunger via the little hole on the underside of the knob. If it's a non detachable type on the choke, disconnect the inner cable at the carbs then pull it back into the car.
If you mean the choke and heater knobs, then Dave has answered your question.
If you mean the sliding heater control knobs (which you have to remove to remove the console), then they simply pull off, although they can be quite tight, and sometimes need some leverage behind them with a cloth to protect the surfaces.
The two parcel shelves ideally need to come out, along with the gearlever surround (the gearknob has to come off too). As Charles says the screws securing the front of the console (in front the gear lever), and securing the rear of the console can be difficult to get out as the threads tend to rust on the underside where they are exposed to the elements. You think they are starting to turn, but they then get very stiff when the rusty threads start to bite. If you can squirt them from underneath (although this is awkward if the gearbox insulation pad is in place) the day before it will help. You need to remove the ashtray, the radio (if fitted) and the heater control facia (there are some black headed screws on either side by the vertical slide controls). Once the wood trim has been removed, the only other fiddly bit is removing the two side screws that fasten to the bracket on the underside of the dash.
It is a bit of a fiddly job, especially the first time, but methodical thinking will get you through it.
Thanks all, much appreciated. I didn't get round to the job this weekend but it's on the list for next weekend. I'll let you know how I get on.
1977 2500S - White
1977 2500S - White
You can leave the gear knob on, and feed the trim pad through the aperture in the console I think!
Personally, for the time it takes to remove the gear lever knob, its not worth faffing about and risking damaging the surround. Good undamaged ones are getting harder to find...
