Steering column splines.
Hi all , does anyone off hand know how many splines there are on the steering column of my mk1 68 2000 , as I'm looking at getting a new wheel , so I need to know what boss to get . and I have been asked the shaft diameter at the same time , if its on record some where it would save me trying to count them
Re: Steering column splines.
Hi Baller,
Newbie here, but asking the same question as you, I don’t suppose that you found the answer by chance?
I have a Mk1 steering column off a car. I will count the number of splines and the overall diameter and post the results tomorrow (Tues).
Thanks johnnydog
After going 'bogeyed' and a couple of recounts, there are 48 splines. The shaft diameter immediately below the splines is 1.75cm (11/16") and the od diameter of the splined area is 1.9cm (3/4").
Hope this helps.
Hope this helps.
I have a Moto-Lita wheel on my Stag, so I emailed them to see if any of their wheel bosses will fit. This is the reply
Hi Chris
A B23 will fit one of our standard wheels. Boss price is £54.00 plus VAT, the wheel is extra, plus shipping.
https://www.moto-lita.co.uk/bosses/b23/
Kind regards
Jill
Thanks johnnydog - that helps a lot brilliant.
Hi Chris
Kind regards
Jill
