Heater Valve
Sloppy 2000
Heater Valve
#1 Post by Sloppy 2000 » Sat Apr 07, 2018 3:05 pm
Sadly, after a really nice run in the warm sunshine, I found on my return that the heater valve was leaking.
Does anyone know which are compatible?
I have found this for about £34 https://www.ebay.co.uk/itm/JAGUAR-MK2-V ... XQya1Q7KFX
However there are a few which look exactly the same for much less. Does any one have a part number or suggestion?. Jeff
Triumph 2000 estate mk1 1968
Re: Heater Valve
#2 Post by johnnydog » Sat Apr 07, 2018 8:57 pm
Hi Jeff,
The Triumph part number for the water valve is 570230.
The one in the link looks the same but without comparing it with an original, I can't say with 100% accuracy.
I can check Sunday morning to see if I have an original spare to compare with the new one in the link, or if I have one, whether a used one is any use to you.
John.
Re: Heater Valve
#3 Post by Alec » Sun Apr 08, 2018 7:48 am
Hello Jeff,
The Jaguar MK 2 does use a valve that is very similar to the Triumph Mk 1. However I note the seller is Ashley Hinton who trades in heaters and accessories amongst other things so I suggest that he probably is correct in saying it fits the Triumh.http://www.mg-cars.org.uk/ah/index.htm.
I bought one earlier this year but from Chris Witor, and I know he charges a deposit until you send back your old unit so he can restore the steel bits and reuse them.
Jaguar X Type Estate 2.5
englishbull
Re: Heater Valve
#4 Post by englishbull » Mon Apr 09, 2018 10:59 am
the on in the link is correct.
Fitted one to my MK1
No Pi's in my garages
1964 MK1 2000 SaloonConiferMOD
1985 MG Maestro in Silver
1999 Rover 820 Vitesse Turbo in Blue
1962 Triumph Tina Scooter Red
2012/14 RBRR Finisher in Car 94 TEAM 59 RBRR2014
Peter Douglas W
Re: Heater Valve
#5 Post by Peter Douglas W » Tue Apr 10, 2018 10:28 am
I don*t understand. If Triumph tried to use common parts, why are we going to MG or Jaguar or or to get a valve which is standard on the TR series? The TRs have the same engine, so why should they have another valve? I am not talking about quality. :? :? :?
Peter Douglas Winn
A happy Triumph owner.
Sloppy 2000
Re: Heater Valve
#6 Post by Sloppy 2000 » Wed Apr 11, 2018 10:15 pm
Hi Thanks all,
I think that it was originally a LUCAS part and hence the interchangeability, just guessing, wouldn't stake my life on it or anything
Jeff
Sloppy 2000
Re: Heater Valve
#7 Post by Sloppy 2000 » Wed Apr 11, 2018 10:23 pm
Just as well I didn't stake my life on it, Smiths not LUCAS
