It is currently Thu Sep 21, 2017 5:47 pm
Post new topic Reply to topic  [ 14 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: What a plonker!
PostPosted: Thu Sep 07, 2017 8:02 pm
Offline
Tonight whilst playing with the electrics trying to solve a problem, I managed to connect a live feed wire from the n/s rear light to the earth side of the rear number plate bulb. The rear lights are now very dim. Anyone with a clue as to what I've done. Please help!!
_________________
Dorset Badger
MK2 2000 m/od. Sapphire Blue.
Top
 Profile
 Post subject: Re: What a plonker!
PostPosted: Fri Sep 08, 2017 10:49 pm
Offline
Dim rear lights might mean you've done something to the night dimming relay if you haven't already disconnected it.
_________________
John Lee
1966 Triumph 2000 Mk1 "LuLU" (the Lee family Triumph) - various shades of Green - Currently on SORN. Requires the engine sorting and a bit of bodywork.
Top
 Profile
PostPosted: Sat Sep 09, 2017 4:18 pm
Offline
Thanks for the reply. The brake lights are also dim too. Whereabouts is the relay?
_________________
Dorset Badger
Top
 Profile
PostPosted: Sat Sep 09, 2017 4:25 pm
Offline
Aha, after reading another post, it's in the boot. Thanks for your help. I will update tomorrow after I've "played " with it.
_________________
Dorset Badger
Top
 Profile
PostPosted: Sat Sep 09, 2017 4:33 pm
Offline
It's behind the n/s boot hinge. Pull off the black Earth wire to bypass it and all should be well.
_________________
LYB864K 1972 Lines Stag Estate Tartan Red "DEL33"
Top
 Profile
PostPosted: Sun Sep 10, 2017 3:02 pm
Offline
Blast, the lights are still dim, any other suggestions please?
_________________
Dorset Badger
Top
 Profile
PostPosted: Mon Sep 11, 2017 6:59 am
Offline
Hello Badger,
you may have overheated a connection, you'll need to look at areas like the light switch, there should be visible darkening if that's happened. Alternatively use a multimeter if you have one to check any terminations from source back to the lamp. If the earth point is common to the numberplate lamp and the rear lights then check that also.
_________________
Jaguar X Type Estate 2.5
Top
 Profile
PostPosted: Tue Sep 12, 2017 6:34 am
Offline
Sounds like the night dimmer has latched on to me, if the obvious is not the battery. On the night dimmer try disconnecting the green and purple wires and temporarily bridge them then disconnect the earth and bridge it onto the body. Then that might indicate a faulty relay. However the fault could be at the switch end if there is corrosion bridging the park light and side light position. Best I can come up with.
_________________
Ross Taylor
Top
 Profile
PostPosted: Wed Sep 13, 2017 3:09 pm
Offline
Disconnecting the earth wire only stops the Night Dimming Relay operating in dim mode. I suspect that you have seriously damaged its inner workings so the best solution is to remove it and bridge the relevant wires. That's what I have done. The simplest way is to get some 'Lucar' double males (1/4" tabs) to bridge the wires. There are 3 or 4 of them to bridge, but use a circuit diagram to work our which wire colour goes to which. Make sure everything is suitably insulated when you have finished!
The Night Dimming Relay doesn't do any thing useful really, so its removal is probably the best solution in the long run.
Good luck!
_________________
Top
 Profile
PostPosted: Wed Sep 13, 2017 6:08 pm
Offline
Hello Mike,
correct me if I am wrong but surely the night dimming relay only dimmed the brake and indicator lamps, not the tail lights?
I still feel that the extra current drawn by shorting the circuit to earth overheated an already marginal termination and made that worse?
Alec?
_________________
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
