diff seal
New to the forum? Just joined the Register? Introduce yourself here.
Sloppy 2000
diff seal
#1 Post by Sloppy 2000 » Mon Sep 04, 2017 5:17 pm
I have a leak where the nose joins onto the diff. Its a fair drip now, and my mum is complaining of it on the garage floor. She has a point. I can't keep relying on pieces of cardboard on the floor.
Does anyone know how to replace this seal. Jonny Dog said get some advice as he has never had to do one, but he has heard that this could be repaired by taking the prop shaft off. If this is so, it would cheer me up and a sweet old lady.
Triumph 2.5PI Valencia
Re: diff seal
#2 Post by tony » Mon Sep 04, 2017 6:54 pm
Sorry, but looks like the pinion seal needs replacing. The oil will also have washed the grease from the quill shaft bearing which is a sealed grease filled one. this will also need replacing.
Not the simplest of jobs. The nose piece will need to come off. I've always dropped the diff to do this but better brains than mine will tell you it can come off with the diff in place.
Re: diff seal
#3 Post by johnnydog » Mon Sep 04, 2017 7:27 pm
Just seen this post Jeff - how come you posted it in 'Introduce Yourself'?
It may get a better response in the Transmission section of Technical Questions!! :D
Re: diff seal
#4 Post by Charles H » Tue Sep 05, 2017 7:58 am
Jeff
It does require the diff to be removed to replace the seal. Secure the car with the rear supported on good stout wood spreaders under the sills. Undo the four bolts at the front where it meets the quill shaft/subframe and two at the rear. Seal is an easy replacement with the diff off. You will need to remove the exhaust rear section to allow the subframe to pitch downwards.
The quill shaft bearing can be replaced with the propshaft unbolted from under the car. Use a quality bearing from reputable suppliers like Chris Witor, or you will be doing the job again pretty soon! Guess how I know!
Re: diff seal
#5 Post by Mike Stevens » Tue Sep 05, 2017 9:17 am
In addition to Charles' post, don't forget to undo the handbrake cable at one brake back plate. If you don't, the whole subframe assembly will hang on the handbrake cable!
This is not a difficult job. The oil seal is just inside the diff where it bolts to the nose piece - not in the nose piece itself. The seal runs on the quill shaft that is part of the nose piece assembly. You ought to check the outside of the quill shaft where the seal runs as that can also get marked.
The front bearing is just behind where the prop bolts and is easy to replace when the nose piece is removed from the diff. Remove the front (big) circlip and the whole assembly can be driven out forward. Then change the bearing - with a 'good' one as already suggested. Also for the seal! As the books say, replacement is the reversal of removal!
Sloppy 2000
Re: diff seal
#6 Post by Sloppy 2000 » Sun Sep 10, 2017 10:02 pm
Hi All
OK it is starting to make sense.
Why am I standing the car on the cills. when you say a wood spreader how long how wide etc.
I know I will be able to manage getting diff off, I just need to know how to stand the car for this one. Thanks everyone, this is very helpful advice.
Jeff
Re: diff seal
#7 Post by Charles H » Mon Sep 11, 2017 7:53 am
You cannot support the rear of the car on the subframe, because you need it to droop to get the diff off the back of it. The car weight at the rear must be supported on the sills. A piece of 2" x 4" would be about right, probably 3ft long ish plus!
Sloppy 2000
Re: diff seal
#8 Post by Sloppy 2000 » Thu Sep 21, 2017 7:23 pm
I am wondering about whether when I separate the nose, what to expect. I am assuming the the seal is just in the lip inside. Nothin else is going to drop out. Also when I reattach the nose, is there a gasket I ought to have handy or is the seal all that is required.
Jeff
Re: diff seal
#9 Post by Charles H » Fri Sep 22, 2017 7:30 am
No, no gasket or anything else to fall out. You will have some oil come out though once the diff moves back.
