It is currently Mon Jul 24, 2017 4:44 pm
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Prop shaft flange
PostPosted: Sat Jul 15, 2017 7:18 pm
Offline
Hello, Can someone advise me the size of the nut that holds the prop flange on the gearbox output shaft, I intend to replace the oil seal and want to make sure I have everything to hand, Thanks in advance Kenny.
Top
 Profile
 Post subject: Re: Prop shaft flange
PostPosted: Sat Jul 15, 2017 11:02 pm
Offline
They are 3/8 UNF and 1 1/8" long, tightened to about 25ft lbs (or as tight as you can reasonably do them!)
Just a question - why do you want to replace the original? When they have been removed previously, have the nyloc nuts been partially rounded by the use of an open ended spanner? I use a thin ring spanner on the head, and a thin wall 1/4" drive 9/16 AF socket on the nut with a 1' long breaker bar, as it's usually not possible to get an opened spanner on the nut fully and this risks rounding the flats if it slips. This way it's possible to break each nut without risking an opened ended spanner slipping.
_________________
Top
 Profile
PostPosted: Sun Jul 16, 2017 6:17 am
Offline
As above. Nice Stahwille ring spanners for me. NO open enders . Not 1/4" but 3/8: x 9/16" socket. :shock:
_________________
1976 2500 TC.
1997 BMW 523i.
Hopefully don't need bits !
Top
 Profile
PostPosted: Sun Jul 16, 2017 7:21 am
Offline
Thanks for the replies, Sorry if did not make myself clear , I actually meant the nut that holds the prop flange to the out put shaft,
Top
 Profile
PostPosted: Sun Jul 16, 2017 11:47 am
Offline
If you mean the large castellated nut / nyloc nut on the end of the mainshaft rear flange that bolts to the front end of the propshaft, then they are 3/4" UNF. The specified torque is 100-110 ft lbs.
_________________
Top
 Profile
PostPosted: Sun Jul 16, 2017 4:09 pm
Offline
Done this myself recently, you need something handy to hold the gearbox flange when you unscrew the retaining nut.
I'm not keen on wrenches around the collar, so use a piece of flat bar like the photo below - bolt to the gearbox side of the flange and hold while you loosen and re-tighten the flange retaining nut. Its a piece of 25x10mm flat bar about 250mm long with a 10mm hole with a relief ground out to clear the flange collar. Anything similar will do as long as it is stout enough not to bend.
Pete
Top
 Profile
PostPosted: Sun Jul 16, 2017 5:38 pm
Offline
The socket required is 1-1/8" AF.
_________________
1970 2500 Mk2 in pimento red
Vauxhall Omega 3.0 Elite
Vauxhall Vectra C Design lpg
Vauxhall Insignia SE
Top
 Profile
PostPosted: Mon Jul 17, 2017 6:09 am
Offline
Thanks to all who replied? :D
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
