Converting to Stag rear drums...
Hi all,
Seeing that MkII rear drums are no longer available, what's involved in converting to the Stag setup?
If not wise, then has anyone got a pair of MkII drums stashed away that they no longer need?
Re: Converting to Stag rear drums...
There has been a very recent thread on converting to the Stag set-up. Do a search on rear brakes or something like that.JimB wrote:Hi all,
What's wrong with your old drums Jim? If they are not badly oval or worn they should be fine. If not, I'm sure I can find a pair!
I've not forgotten your need for a clutch bearing carrier, I've just not had time to look yet...
Personally, I'd be a bit careful about changing the drums to Stag setup without also changing the discs etc. You might upset the front/rear brake balance.
Huh
JimB wrote:Seeing that MkII rear drums are no longer available
http://www.chriswitor.com/proddetail.php?prod=210578A
http://www.chriswitor.com/proddetail.php?prod=216461SH
I just did the rear drums on mine Mike as I don't think the discs are radically different.Mike Stevens wrote:What's wrong with your old drums Jim? If they are not badly oval or worn they should be fine. If not, I'm sure I can find a pair!
canley classic stock new
216461 BRAKE DRUM - 2000 2.5 MKII £28.00 EACH IN STOCK
Pete
Pete
Pete Lewis
Luton
Luton
Stag discs are bigger in diameter (which is why 13" wheels won't fit onto them) and there are others who have fitted Stag brakes so I guess the braking force could well be more than a standard 2000 setup. Not that there is anything wrong with the 2000 setup!torque2me wrote:I just did the rear drums on mine Mike as I don't think the discs are radically different.
I just wanted to air the view that fitting Stag rear brakes but keeping standard 2000 fronts might cause a brake imbalance. Note that I have not done it so am not speaking from experience!
With 14"wheels I found stag fronts were well cheaper than 2000 mk2
so she has stag disc and calipers but std rears apart from the stag hand brake shoe spreader
Pete Lewis
Luton
Luton
I was just letting the groupies know that changing to Stag drums has not created any great imbalance on mine. Pete, doing it the other way is also interesting.Mike Stevens wrote:Stag discs are bigger in diameter (which is why 13" wheels won't fit onto them) and there are others who have fitted Stag brakes so I guess the braking force could well be more than a standard 2000 setup. Not that there is anything wrong with the 2000 setup!torque2me wrote:I just did the rear drums on mine Mike as I don't think the discs are radically different.
It years since I could reel off part numbers and the differences but if the front discs are different size wise then it is (warning, warning - guesstimate) probably 1/4" (9.75" against 9.5"?). As GBP242 is the only pads available now and these were spec for the 2.5 I would guess there is little to be gained from using the Stag disc. After all, it cannot grip a larger area and on my 2.2 mk.2 there is about 1/8"th top of the disc unsweapt.
CW did a comparison test of various combinations in Six Appeal some years back. I think he gave a small percentage gain for Stag disc/(drum?) setup. As I say, I'm unconvinced with a 242 pad usage.
