engine mounts
DDAY
Re: engine mounts
#21 Post by DDAY » Sat Oct 29, 2016 8:14 am
Fingers crossed this works! :)
Also got hold of a good gearbox mount as mine was in two and strengthened it up a little due to poor design!
Behind every great man there's a woman rolling her eyes.
Re: engine mounts
#22 Post by Clifford Pope » Sat Oct 29, 2016 1:58 pm
The first pics worked for me.
You mean there is a projecting stud on the Rover which you have to grind off?
(keeping it cool to avoid melting the rubber?)
DDAY
Re: engine mounts
#23 Post by DDAY » Sat Oct 29, 2016 5:01 pm
Clifford Pope wrote:The first pics worked for me.
They are a stud and a stud a symmetrical engine mount, hence why I've had to drill a hole in the bottom of crossmember to wind the nut on the bottom of the mount! :)
Re: engine mounts
#24 Post by Dave B » Sun Oct 30, 2016 10:56 pm
I can see what you mean, the two original mounting holes are now redundant and the mount is now held by the lower stud on the mounting and the securing nut is accessed via an extra hole you have drilled in the lower side of the crossmember, presumably large enough to allow a socket in.
http://www.ebay.co.uk/itm/P38-RANGE-ROV ... XQlgtSyAt8
Definitely worth the mod providing the mounts are good quality.
1970 2500 Mk2 in pimento red
Vauxhall Vectra C Design lpg
Toyota Avensis TR
