Wipers
CP Sargent
Wipers
#1 Post by CP Sargent » Sun Jan 17, 2016 10:10 pm
Hi all
The wipers on my mk1 are very slow to come on when I flick the switch on and then work there way slowly across the screen is it the switch or the wiper motor or where should I be looking cheers Pete
1967 yellow mk1 saloon
1968 damson vitesse convertible
1970 valenica blue herald saloon]
1990 red Fiat 126
Re: Wipers
#2 Post by tony » Mon Jan 18, 2016 2:49 am
Probably the motor. Brushes and / bearings usual suspects or could be semi seized wheel boxes.
1998 Rover 600
david_rachel
Re: Wipers
#3 Post by david_rachel » Mon Jan 18, 2016 8:32 am
You might be lucky and be able to sort it by re-greasing the rack.....try turning the wheel box spindles 180 deg before re-inserting the rack, and also turn that 180 deg and you might be okay
David Rachel
1978 Carlight Casetta Caravan
