Alternator rating
Alternator rating
Hi All,
Following on from a FB posting about my Halogen conversion, i was wondering what rating of alternator people use?
for info i have added the halogens X 4 that are rated at 130% above normal halogens, but clame same power rating
still to add would be the phone charger, radio and sat navs etc
cheers
cheers
Ian Peacock
still sane? definitely not!!
Mk1 2000 Estate Wedgwood Blue
Re: Alternator rating
To be honest, compared to the headlamps, things like satnavs, phone chargers etc. draw peanuts in power!
The standard 15/16/17ACR were rated at 25-35A output. 4 headlamps draw about 16A and then if you add rear screen heater, blower motor (fuel pump if a PI!), you are getting well above 25A.
In my PI I have an uprated alternator (it was already fitted when I bought the car). I can't remember the rating, but it is in excess of 45A. That does seem to cope OK.
It is also worth looking at the wiring from the alternator. If you have 2 thick brown wires, then that's the later type and is probably OK. If you have 1 thick and 1 thin, then that was designed for a battery sensed alternator but the modern replacements are machine sensed and so it is well worth fitting extra wires between the alternator and the battery. Also don't forget the negative connections too. If the alternator is giving 30A, then this current flows through the positive wiring to the load and then back through the engine and alternator casing. I have also fitted a negative wire from the battery negative terminal to the alternator body.
- Andy Thompson
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
- david_lall
Agreed. I have the same on my car.Andy Thompson wrote:http://www.ebay.co.uk/itm/Land-Rover-Di ... 1519176022
This sort of thing is perfect
David Lall
1978 Carlight Casetta Caravan
Andy,
I liked that too, until I saw the $88 postage cost to NZ.
1998 Rover 600
1998 Rover 600
cheers, i can not quite make out if is has a built in regulator or not? as you have them would you be able to shed any light on it?
Ian
Ian
Ian Peacock
- Andy Thompson
Surely the same sort of thing is available in NZ - very common alternator on Land Rovers and Jagstony wrote:Andy,
I liked that too, until I saw the $88 postage cost to NZ.![]()
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
You're probably right, haven't really looked
1998 Rover 600
1998 Rover 600
