Ignition light
CP Sargent
Ignition light
#1 Post by CP Sargent » Sun Sep 27, 2015 8:24 pm
Hi mk1 starts fine and runs good but at 65/70mph the ignition light flickers on and off but dosent effect running , it has a new battery and a new coil fitted any one have any ideas on what to check , look for cheers Pete
1967 yellow mk1 saloon
1968 damson vitesse convertible
1970 valenica blue herald saloon]
1990 red Fiat 126
Re: Ignition light
#2 Post by tony » Mon Sep 28, 2015 3:11 am
Suggest the dynamo/alternator needs an overhaul.
1998 Rover 600
Re: Ignition light
#3 Post by Charles H » Mon Sep 28, 2015 8:44 am
Agree with the above, however if you are still running a dynamo, it could be the control box which is low down on the front offside in under the air box intake pipes. :)
CAR
Re: Ignition light
#4 Post by CAR » Mon Sep 28, 2015 11:42 am
could even be as simple as a fanbelt loose. Difficult to hear at higher revs.
Re: Ignition light
#5 Post by Mike Stevens » Mon Sep 28, 2015 12:08 pm
If you have an alternator, most likely the brushes have worn. They seem to do about 70k miles before giving trouble.
If a dynamo, then as Charles says, you need to look at the regulator, although it could still be the brushes!
CP Sargent
Re: Ignition light
#6 Post by CP Sargent » Mon Sep 28, 2015 6:24 pm
Hi all thanks for replies , the car is running a alternator which was on the car when I got it about 3 yeers ago so don't know much about it , will have a look when I get some time
1990 red Fiat 126
