engine mounts
widget
Re: engine mounts
#11 Post by widget » Tue May 19, 2015 5:24 am
james is currently out of stock
MK1 2000
Herald 1200
MK3 Fiesta
widget
Re: engine mounts
#12 Post by widget » Wed May 20, 2015 5:13 pm
Dave B wrote:
widget wrote: These must be worth a punt at the price......not listed as Triumph/Jaguar/MG etc but the same as our cars.
https://www.vibration-mounts.co.uk/View ... 0Kg-M8-266
i'll check the dimentions against the one on the car...might be worth getting as a stopgap till james has some in
MK1 2000
Herald 1200
MK3 Fiesta
Triumph only
Re: engine mounts
#13 Post by Triumph only » Mon Jul 04, 2016 12:01 pm
Lee show mine were completely worn out during last National!!! They were brand new 5 years ago...
Fortunately Thorsten had very effective ones if not cheap you can find here:
http://aws-cf.caradisiac.com/prod/photo ... b7.jpg?v=1
Ordered, to be followed.....
Michel Grimaldier
ET447DZ(Betty) 1969 2.5PI MkI. 2018 RBRR DNF
BQ529TJ(BBQ) 1971 2000 MkII 1970 RMC lookalike. 2014 RBRR finisher.
700FW69(Valentine) 1970 2.5PI MkI Restoration project
SimonO
Re: engine mounts
#14 Post by SimonO » Tue Jul 05, 2016 5:23 am
Only uprated ones I can find are the Vibra-Technics ones on ebay;
http://www.ebay.co.uk/itm/142038924555
Dazzer
Re: engine mounts
#15 Post by Dazzer » Tue Jul 05, 2016 9:44 am
After numerous engine mount failures during competition I sent an engine mount to vibra tech and they made some up from Caterham mounts I think. Been on four years now perfect.
Three times the price of standards but fit and forget.
Dazzer
Re: engine mounts
#16 Post by tony » Tue Jul 05, 2016 6:34 pm
Greg Tunstell in Australia also has good one's. They're not cheap but don't fall apart.
1998 Rover 600
Triumph only
Re: engine mounts
#17 Post by Triumph only » Tue Jul 05, 2016 6:39 pm
SimonO wrote:Only uprated ones I can find are the Vibra-Technics ones on ebay;
Oups, I posted the wrong link... It is Vibra-Technics as well, direct link:
http://www.vibra-technics.co.uk/mg_rove ... gine_mount
Michel Grimaldier
herald1360
Re: engine mounts
#18 Post by herald1360 » Wed Jul 06, 2016 9:17 pm
Hi Al
I fitted new engine mounts supplied by Canley classics about £7.00 each all good after about 2 years
Hope this helps
Paul
Paul Barlow
Exeter
1974 2500TC French blue
DDAY
Re: engine mounts
#19 Post by DDAY » Fri Oct 28, 2016 10:15 pm
This is the easy engine mount modification I made/found, working in a breakers yard my eyes where peeled for something better!
Anyway this is what I found, P38 V8 Range Rover gearbox mounts. Small modification as you can see to take the bottom stud, been on over a year now and no signs of wear!
Images: https://www.flickr.com/photos/144504807 ... res/NUA14L
Hope you can see images!
Behind every great man there's a woman rolling her eyes.
TedTaylor
Re: engine mounts
#20 Post by TedTaylor » Fri Oct 28, 2016 11:47 pm
DDAY wrote:Hope you can see images!
Nope :(
MUT
