Production figures
- Newbie
Agreed,excellent article by Andy,looking forward to the part 2 alluded to. Particularly interesting note regarding the facelift estates. Wondered what the world total produced might be; presume the uk figures don't include ckd kits or vehicles produced in SA/OZ etc. now there's a challenge....!
1970 2000 mk2 saloon. Valencia
Re: Production figures
I'm fairly sure all estates were English assembled . None built in New Zealand.
- multipleprototypes
One interesting thing I did find in the production records for facelift PI Estate's.
Production started to tail off w/e 15/4/74 (only 7 cars built), finally finishing with 3 cars built w/e 13/5/74.
Only it didn't because in w/e 5/8/74 a sole example is shown being built. Strange that after nearly 3 months out of production they go to the trouble of building another.
By Royal Appoinment? Prince Phillips car?
Last edited by multipleprototypes on Thu Feb 05, 2015 5:02 pm, edited 1 time in total.
What do I know?
Also noted in the records on the last day of production for saloon's on the 19 May 1977 (2000 ME29535, 2500TC MM39373, 2.5S MP10237) is the sarky comment,
'No Champagne For Workers' !
A sign of industrial relations in the Midlands in the 70's?
What do I know?
Fascinating info Dave - would you be able to bring some examples of the records to Stoneleigh, assuming you'll be there?multipleprototypes wrote:One interesting thing I did find in the production records for facelift PI Estate's.
Production started to tail off w/e 15/4/73 (only 7 cars built), finally finishing with 3 cars built w/e 13/5/73.
Only it didn't because in w/e 5/8/73 a sole example is shown being built. Strange that after nearly 3 months out of production they go to the trouble of building another.
Facelift cars in 1973? Wasn't the market introduction early 1974?
I double-checked with my Best Man*: the bodies are stamped after Paint and after the doors are removed, in a way that doesn't damage the paint enough to cause corrosion. There are then a couple of VIN stickers and the tag you can see on the dash through the windscreen.CAR wrote:But the VIN is pressed in the bodyshell in a few places on modern cars too isn't it Jim?JimB wrote:Modern practice is to assign the VIN as the painted body exits the paint buffer and goes onto the final assembly line.
* He runs Assembly at Goodwood
Yes should have worn my specs.JimB wrote:[quot
Edited.
What do I know?
I'll throw a body number into the mix
122547 if this is any help colin, build date 3.12.70 with dispatch 7.12.70
Have you done the heritage certificate for Frank? This may give you the accurate? dates taken from the build register
Julian
(Slightly off topic but still triumph)
I have a similar issue with my mk1 GT6 as I believe it may be one of the last off the line
Comm no. KC 13700
Thomason says last was KC13752
Am I the youngest survivor?
Julian
Comm no. KC 13700
MK1 GT6 1968 C toC 2021
Mk2 PI 1970 RBRR 2016
