WANTED: alloy rocker cover fixing nuts x3
has anyone got any fixing nuts they dont need for the rimmers alloy rocker cover?
if so, let me know price inc postage and will send cheque. ta.
- TedTaylor
Re: WANTED: alloy rocker cover fixing nuts x3
Did it come from Bedford by any chance ...... I was after some once and they were not available separately though may possibly be able to find the ones that I had off this cover (which the Bedford guy still owes me for).
You can use a fibre washer that is a tight fit on the stud and a washer to protect it before using a nylock nut to screw it down. This should provide sealing to all potential leak points.
You may be able to make the Mini ones fit - they are the ones I bought (off ebay) for my SAH covers (not from Bedford or Caister .....). If you do try them they will require the hole in the cover to be opened out and I am not sure whether the length of the stud is OK because these nuts are blind.
Ted
Ted
Have you looked into the Austin C series ones I suggested?
I'm 90% sure they will suffice
- TedTaylor
If I can find them mine are original chrome ones - the Mini ones are also nicely chromed and quite cheap.
Ted
Ted
- TedTaylor
Found them.TedTaylor wrote:If I can find them mine are original chrome ones - the Mini ones are also nicely chromed and quite cheap.
Ted
Ted
with the alloy cover on the car, the studs dont stand above the holes so normal nuts are no good.TedTaylor wrote:Did it come from Bedford by any chance ...... I was after some once and they were not available separately though may possibly be able to find the ones that I had off this cover (which the Bedford guy still owes me for).
Ted
hi sean, im looking generally at the mo so will look at all types.
- TedTaylor
The correct ones for this cover.TedTaylor wrote:Found them.TedTaylor wrote:If I can find them mine are original chrome ones - the Mini ones are also nicely chromed and quite cheap.
Ted
Ted
thanks ted. PM sent.
ted,
i need 3 for a triumph tune one i picked up last week, any chance ??????
cheers matey
lloyd
cheers matey
lloyd
