Sill replacement`
Hello Jim,<br>
<br>
I have done it that way without any problems, supporting the car on the
main front chassis rail and the rear subframe mount (outer)<br>
<br>
Have a look inside the car along the inner sill and floor joint. This often needs repairing, unfortunately. <br>
<br>
Alec <br>
<br>
<br>
<edited><editID>Alec</editID><editDate>38596.5947685185</editDate></edited>
<br>
<br>
<br>
Alec <br>
<br>
<br>
Brian,
Will do!. The previous owner fitted a skin sill having been quoted £800 to repair the one side correctly. I had a quick poke through the inner sill and could feel the membrane moving. I expect that this is rotten. I think my main problem will be knowing where to stop with the repairs<IMG>!
Regards
Jim
Regards
Jim
Hi Jim
For your interest log onto this site <A>http://www.200025pi.co.uk/</A> and you will find some interesting restoration photo\'s. Once in click on ..Site Links.. Gallery Cars, pictures of cars sent in from U K and overseas... arrow down and click on Dave\'s MK 1 P I New Zealand... then click on .. body work or what ever. Have a good weekend trust it all goes well .
Regards Harold
Regards Harold
Harold,
Thanks for the link. Sorry for the late reply (been away on holiday)! Well.... removing the outer sill revealed plenty of rust flakes and very little metal. The inner membrane is shot as is the inner sill. I have ordered an inner membrane with nose section, outer skin sill, jacking points, cross member and rear wing repair. I will patch the floors where necessary. I think the rear spring support is OK though there is some corrosion around the edges where it meets the floor. What I\'m planning on doing is removing the nearside 1/2 subframe as the floor is shot here also. I\'m trying to make these repairs as neat as possible so I need this out of the way! What I\'d like to know is is OK to remove the 1/2 rear subframe and support the car on the spring mount?
Regards
James
Regards
James
Keep checking the way the doors fit as you go. I usually find a jack across the front outrigger - Chassis Rail allows me to adjust the front door fit.
My normal route is two axle stands in line with the diff and two axle stands on the front suspension cross member. Then a jack on the front out rigger to correct any sag.
What a weekend! I managed to remove 1/2 of the rear suspension including the subframe. The rear of the car is supported on the crossmember behind the diff. The doors open and close fine!
Amazingly the only trouble I had was the exhaust (had to cut it) - all of the other bolts were easily removed. I had a marathon session with the grinder and most of the rot is now removed. Looking forward to the welding!
Will let you know how I get on!
Regards
James
Regards
James
Have you cut off the lower part of the front wing? The bit that covers the sill. This is where the majority of the damage comes from caused but water running down the inside wing and the rotting out the front of the sill.
I like the idea of sealing the wing - windscreen surround to stop the cause of this.
