MkI Heater Label
Richard B
MkI Heater Label
#1 Post by Richard B » Thu Jul 06, 2023 7:22 pm
Does any one know what the Code and Model number should be for the label on the heater MkI post facelift (1967-1970)
This is a landrover one as an example
Richard
Compulsive PI'er :) Daughters have Heralds. Son-in-laws have 2.5's
Richard B
Re: MkI Heater Label
#2 Post by Richard B » Thu Jul 06, 2023 7:25 pm
Its kinda hard to tell on my original heater...
Richard
iani
#3 Post by iani » Fri Jul 07, 2023 2:28 pm
I don't suppose you kept a record of what seals go where? I am refurbing a spare heater box for my Estate but it came empty, I have bought both sets of seals from CW but no list given as to what fits where, some are obvious, others less so?
Richard B
#4 Post by Richard B » Fri Jul 07, 2023 7:04 pm
Richard
Richard B
#5 Post by Richard B » Fri Jul 07, 2023 7:08 pm
The seals I took off, may not have been original or in the right place.
I did think it would have been nice to have had a drawing with the kit. As yours is a pre-facelift, the loose flap is half the size of a facelift and you have the three round vents.
Richard
Richard B
#6 Post by Richard B » Fri Jul 07, 2023 7:19 pm
Found the label! This was taken at Paignton. Thank you whoever that car is. Now I need to see if I can get someone to make some! If anyone can corroberate the numbers that would be good.
FHF5505
F500
Richard
iani
#7 Post by iani » Sat Jul 08, 2023 9:58 am
Thanks Richard, I'd got slightly confused as I have a NOS matrix which came with it's original foam attached, it is slightly different from what CW supplies.
#8 Post by Clifford Pope » Sun Jul 09, 2023 4:25 pm
I have a 1967 Mk1 - not sure whether that means pre- or post- facelift - I've never known what that meant. The heater label of the original is unreadable, but the replacement is identical, from an early 1964 model.
It has the 3 holes like yours, and the plate, in excellent condition, reads:
CODE FHF 5505/05
MODEL F.500
#9 Post by johnnydog » Sun Jul 09, 2023 5:13 pm
A (post) face lift Mk1 is easily identifiable as they have the twin eyeball vents in the dash with lower heater controls and leather seats to name just a couple of changes.
Richard B
#10 Post by Richard B » Mon Jul 10, 2023 11:52 am
A Pre-Facelift heater has an oval hole and a small rectangular slot, where it bolts to the vertical face of the bulkhead.
A Facelift heater has a long rectangular slot where it bolts to the vertical face of the bulkhead.
So presumably there are two different model numbers.
Richard
