We’ve been checking around the bodywork for rust on found plenty - of course. The passenger footwell has rotted out at the base of the bulkhead. My question is whether there is a panel available to be welded in or do we need to fabricate something?
All advice welcome
Replacement floorpan
Chris
Member 7910
Magenta Stag 3.0 Man O/D
Member 7910
Re: Replacement floorpan
Cheaper (and easier) than making your own!
https://southwalestriumphs.com/?s=floor ... pe=product
Lloyd is doing sterling work reproducing previously unobtainable panels/repair sections.
Thankfully neither of my two need any yet, but I would go here first if they did.
Thanks Dave, a lot of the rust is in the more upright bulkhead section, where it joins the floor pan, I don’t suppose there’s a panel for that as well?
Chris
Member 7910
Member 7910
the panel you require will be pressed next year, i have just managed to obtain this NOS one for use as a pattern, the o/s will be pressed and the n/s will be fabricated, unless i can find a NOS n/s in the meantime.
i might press the whole panel or just 15" from the bottom upward, the price i am waiting on will dictate
lloyd
lloyd
