door locks
peewee21
door locks
#1 Post by peewee21 » Mon Jan 12, 2015 8:25 pm
Hi All,
On my MK1 both rear doors can be pulled opened without depressing the button, on examination it appears that the locking cog and rotate both ways at certain degrees. Also on these locks pushing the knob down to lock, you can open the doors with the external button.
Both front doors work perfectly
can this be rectified or will replacements be required?
Kind regards
Ian
Ian Peacock
still sane? definitely not!!
Mk1 2000 Estate Wedgwood Blue
Re: door locks
#2 Post by Alec » Mon Jan 12, 2015 9:16 pm
Hello Ian,
I also have the same problem with one of my rear doors but have yet to investigate (the car is not currently on the road).
I anticipate that a strip down of the lock mechanism and a clean and lubricate will cure it. Certainly worth a try. I think that will sort out both problems.
johnconradlee
Re: door locks
#3 Post by johnconradlee » Tue Jan 13, 2015 9:03 am
I had this problem when I bought my car, so I stripped apart the door apart to access the mechanism, took out the lock and then discovered it was just gummed up with old Waxoyl and only needed a squirt of WD40 which I could have done without dismantling the door!
peewee21
Re: door locks
#4 Post by peewee21 » Wed Jan 14, 2015 8:25 am
Cheers, i will have a look this weekend
Ian Peacock
