Estate Tailgate wont hold up anymore.
- Newbie
Has anyone any idea how to repair an estate tailgate that wont hold up anymore. Are there any parts available for them. It appears to have now also broken a metal rod piece inside. I will take the plastic cover off and have a look, but I feel its going to be a pain to fix. Any advice please. Many thanks Keith.
Re: Estate Tailgate wont hold up anymore.
Hi Keith,
Not really!
The hinge is a spring torsion bar, sounds like it has snapped.
You can weld them back together, but I guess finding a use replacement would be best.
Perhaps someone on here might have one?
Ted Taylor I know has a scrap estate which might yield some?....... ted?
If you look on Mike Weaver's Blog (right hand side of this page) just after it came back from the paint shop he had to cut and re-weld this due to a cock up at the bodyshop............ this might give you some clues or even Mike might be able to give you some advice?
Good luck!
Not really!
Good luck!
Ideally you need a new set of torsion bars = probably from an old written off estate.
remove the tailgate, and the trim over the hinges - before removing the tailgate - wedge the hinges so that they are not fully open
then remove the hinge carriers
the old torsion bars can then be removed from the hinges and replaced
it is detailed in the blog as Alan said - its a days work
FF Stag V8 Estate White
TR5 Valencia Blue
Stag Red
Jensen Interceptor MK1 Ice Blue
The Blog to be found at http://standardtriumphcars.blogspot.com/
TR5 Valencia Blue
Stag Red
- TedTaylor
Love to be able to help but I'm afraid that if the one that is on the estate is any good (and by no means certain because it is very rusty) I will need it for myself - sorry.Alan Chatterton wrote:Ted Taylor I know has a scrap estate which might yield some?....... ted?
When I get it out in a day or so I will see what is involved in remanufacture because I believe there are a few people out there in need ....... and from what I hear a good one is a breakage waiting to happen
Ted
If all else fails, how about this.............
http://www.ebay.co.uk/itm/TRIUMPH-2000- ... 35c26b8c8f
- david_lall
Getting them re-manufactured certainly would be a good move forwards.
I've often wondered about some type of telescopic strut too; even a good tailgate is easily blown shut in strong winds. I guess there are many struts that could fit but there would need to be an attachment plate/reinforcing sections added. Not something for a finished car but certainly do-able at restoration stage.
David Lall
1978 Carlight Casetta Caravan
- leesellars
A broom handle will be good until a spring could be sourced.
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
Triumph TR6 PI 1973
Sadly the spring is in the body, not the tailgateDave B wrote:If all else fails, how about this.............
TR5 Valencia Blue
Stag Red
TR5 Valencia Blue
Stag Red
Never had an estate, but should have thought about it, after all, the boot lid springs aren't in the boot lid on a saloonmikew wrote:Sadly the spring is in the body, not the tailgateDave B wrote:If all else fails, how about this.............
TedTaylor wrote:Love to be able to help but I'm afraid that if the one that is on the estate is any good (and by no means certain because it is very rusty) I will need it for myself - sorry.Alan Chatterton wrote:Ted Taylor I know has a scrap estate which might yield some?....... ted?
Ted
hi ted
i did tell you i have a spare for the estate didn`t i ?
just not going to fit it for you as didn`t want to deprive you of the job
cheers andy
