Hello everyone,
I'm in a bit of a dilemma here. I'm on holiday in Germany in my 2000 (the Black Forest) but unfortunately it's developed a fault. Yesterday there was noticable tapping from the engine and while still pulling well the exhaust note was different, uneven I would say. I've had to reset the valve clearance on number 1 cylinder twice now, it was much too wide but I'm still getting some excessive noise, it sounds a little squeaky now. So I took off the rocker cover again and noticed that the first rocker and possibly the 2nd are not getting oil, at least it looks like that on the image. The first ball end looks dry to me and the rocker had a sooty appearance,(getting hot ?).
Does my assumption seem feasable ? Any idea why this might happen and what can I do remedy it and still drive home again ? I'm not due to drive back to the uk till 1st Oct. Any help and suggestions much appreciated.
Thanks,
Michael.
rocker shaft, pushrod ?
Re: rocker shaft, pushrod ?
I would add I have spent this last few months using the car regularly to make sure everything is ok but now it's had to cover over a 1000 miles in a matter of days and it's not happy. Oh dear, I though t I had been thorough but there's always the unexpected.
Michael.
Michael.
It certainly looks dry as a bone! I think at the very least, I would unscrew the rocker ball pin as much as you can with that valve closed, and see if the rocker moves freely. The only other thing you could do is to remove the rocker shaft, which isnt a big job, and see if there is sufficient sideways movement on that and the adjacent pedestal and rockers to see if the oil hole is blocked on the offending rocker.
Hello John, thanks for replying,
so as you say a bit of dismantling and try to clean it to restore the oil flow. I'm going to have a go at it in the morning as I have somewhere to work on it where I'm staying.
My German hosts (farmers) are quite freindly and have offered to get their tractor mechanic to have a look tomorrow evening but I hope to have it sorted by then, I really don't want to be on a transporter if it can be avoided. I'll let you know how it goes, many thanks,
Michael
Michael
Hello Michael,
is the dryness confined to the front of the rocker shaft only? That at least would show that oil is getting to the rocker shaft and that it is probably a blocked oil hole at the front. Just athought, is the rocker shaft locating screw (in the pedestal) in place? If it has dropped out pressure will be lost and as the number one is furthest from the feed that would be starved first?
Thanks Alec, I have had a look this morning and dismantled the shaft, exactly as you say, the screw is missing so it's rocker 1-6 that have suffered, I need a new shaft and rockers, trying to contact Chris Witior now to see how quick delivery is.
Thanks,
Michael
Thanks,
Michael
Hi everyone,
I'm glad to say the car is ok now. I have replaced the missing screw in the rocker shaft with a 5mm one, (it's a close fit), I've locked it in place with a nut and washer up against the shaft as well and I now have oil emerging from the shaft all the way along. It was still running a little rough afterwards but I didn't get the valve clearances quite right, after resetting them all the car is now performing well. I have covered about 200km today without issues.
I would also mention Chris Witor's assistance with his advice, always ready to help, we're lucky to have him.
Thanks for all the replies and suggestions.
Michael
Michael
Good to hear you are back up and running.
