Petrol leaking from filler cap
Could be a simple one this ... out on a run today and noticed on return that fuel had been leaking from the cap. Tank is half full. An aftermarket filler/cap has been fitted by previous owner as per photo with a less than perfect seal - should the cap be vented or am I just not tightening the cap enough?
First time I filled her up it was a devil of a job to undo the cap so I suspect the previous owner just tightened the cap as much as he could to minimise/prevent leaks.
Just surprised with a tank half full that fuel was forced from the cap! I wasn't rallying or going up on two wheels or anything!
Anyone had this and do I just need to put an extra half turn on the cap?!
Toby Crayden
Register member 7985
Gravesend, Kent
1965 Mk1 Triumph 2000
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Re: Petrol leaking from filler cap
second photo
Toby Crayden
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Our Triumphs are notorious for leaking fuel from the filler neck usually on anything above half a tank. That is why some Police Forces (Lancashire being one of them) omitted spray painting the rear nearside wing in the orange Dayglo paint when commissioning their fleets in the 70's, as leaking fuel quickly stripped the fresh cellulose paint, which looked unsightly.
Locking petrol caps are no better in my experience.
I have gone back to the original chromed AC twist non locking fuel cap on all my Triumphs. As long as the seal on the rear is still flexible, they seem to seal better than any other I've tried.
I never leave them anywhere that there is a remote possibility of fuel theft, so that isn't a concern.
Toby
That aftermarket cap appears to firstly have a broken rubber seal on the cap, and secondly the attachment ring on the filler neck will also have a seal. Therefore there are two potential seals to leak. I do the same as John, revert to the bayonet original cap. They are available from CW. I carefully rub off the painted section to look better. https://www.chriswitor.com/proddetail.php?prod=618389RM
After fitting a 'proper' cap check out the breather pipe that should come out under the wheel arch (I think it is the same on the MkI). In the early days I had petrol starvation when the wheel arch got covered with mud and I have heard of people collapsing the fuel tank. I did manage to get an early Unipart locking cap but it was very tricky to fit the locking collar around the pipe flange.
Thanks All
Petrol Cap ordered from CW (although it says not for early Mk1's on the web site and mines a pre face lift Mk1 so fingers crossed it fits!)
I'll try to remove the aftermarket filler neck and revert to the original. I tried giving it a good tug but it wasn't shifting so I'll have to see how its fixed and see if I can remove it.
Thanks for the advice - I'll let you know how I get on!
Toby Crayden
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
I think it is only the extremely early Mk1 that the filler neck (where the cap fits) is different - you should be ok with the age of your car.
I prised off the aftermarket cap but the replacement from CW doesn't fit unfortunately - way too big and only 2 prong - my filler neck is smaller at 1.5" across and 3 prong. Guess someone has replaced the tank at some stage. Now on the hunt for a 1.5" 3 prong cap!
I've put the old filler cap back on and wrapped a rag around the filler neck to catch the leaking fuel and so I can have that mobile Molotov cocktail look and feel ...
Worst case I'll look at another cap/neck that can fit over the top or buy some sealant and try to fit the brass one back on with a decent seal.
I'll let you know how it goes ...!
Toby Crayden
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Thats a bugger!
This is what the filler neck should look like with the two cut outs for the twist AC style non locking cap which I have in all my cars.
This is the the front and back of the AC cap showing the fixing tabs. Should be self explanatory.
I'll check when I can, but I believe earlier cars had a different flared end on the filler neck for the cap.This is the the front and back of the AC cap showing the fixing tabs. Should be self explanatory.
