Electronic ignition
Sorry if this has been covered somewhere in the forum before (couldn't find it)- I want to change to electronic ignition. I can get hold of a Petronix system in NZ, is there better or is that system ok? I have a 2000TC, 1978, manual.
Triumph TC 2000 1978
Triumph Bonneville T120 2018
Re: Electronic ignition
I previously had a Petronix unit which was fine, but have since switched to a 123ignition electronic distributor - https://www.123ignitionshop.com/ - which is noticeable smoother, and I like having the option of adjusting the advance. I have the standard Tune but you can also get the Tune+ if you want to create your own ignition advance curve.
Nothing wrong with the Pertronix unit. Have fitted them to all my Triumphs and a big improvement on points and condenser.
I think the Pertronix is the same as Aldon. The Aldon is a great bit of kit. All my Triumphs have them. I did try a much cheaper Simon BBC one once. The early cars rev counter does not work with it! Aldon would be my advice.
I must try again with Petronix. I had a frustrating experience trying to fit it a few years ago. It seemed as if I'd been sold the wrong kit - the timing was about 30 degrees out, and non-adjustable. The fixing hole in the plate was in the wrong place, and I gave up trying to work out where it should be.
A final annoyance was that the instructions said that if the rotating bit was rubbing on the pick-up, or closer than about 25thou, the hole should be elongated to increase the gap. When I sent the kit back to say it appeared to be the wrong one they refused a refund because I had followed this advice and modified the hole.
I got the kit back again but have never tried to see if I can make it work. It hardly seems worthwhile now the standard points are working well.
A mechanic has suggested a 'drop in' as opposed to a kit, if that makes sense. Can anyone suggest a brand for that. I noticed there is a Chinese brand called Sherryberg that has one available but a bit nervous about putting an unknown brand in my car.
https://www.classicheads.com/Electronic-Ignition/
Both my Triumphs have been fitted with a kit from these guys, and have never missed a beat in over 10 yrs in the blue car, and over 15 yrs in the red car. I have never had to adjust anything once they were set up, they have been completely reliable, I would never go back to points and condenser. All the "gubbins" of the kit are under the dizzy cap, so a cursory glance under the bonnet everything looks standard. I have also bypassed the ballast resistor and fitted a 12v coil, along with a modern 'red' rotor arm.
Issue summons in the Small Claims Court and see if that doesn't get their interest.Clifford Pope wrote: ↑Mon Sep 03, 2018 8:38 amI must try again with Petronix. I had a frustrating experience trying to fit it a few years ago. It seemed as if I'd been sold the wrong kit - the timing was about 30 degrees out, and non-adjustable. The fixing hole in the plate was in the wrong place, and I gave up trying to work out where it should be.
Hint: Companies cannot represent themselves in court and thus they will need the service of a Barrister. What do they charge of a 1/2 day? A no brainer. Of course it all depends on how much you want one's nose put out simply to bring that company to heel!
Users browsing this forum: Bing [Bot] and 10 guests
