Electronic ignition
Ltriumph
Electronic ignition
#1 Post by Ltriumph » Sun Sep 02, 2018 12:04 am
Sorry if this has been covered somewhere in the forum before (couldn't find it)- I want to change to electronic ignition. I can get hold of a Petronix system in NZ, is there better or is that system ok? I have a 2000TC, 1978, manual.
Triumph TC 2000 1978
Triumph Bonneville T120 2018
Phil T
Re: Electronic ignition
#2 Post by Phil T » Sun Sep 02, 2018 10:38 am
These people are reputed to be very good.
https://simonbbc.com/
Joe™
#3 Post by Joe™ » Sun Sep 02, 2018 11:37 am
I previously had a Petronix unit which was fine, but have since switched to a 123ignition electronic distributor - https://www.123ignitionshop.com/ - which is noticeable smoother, and I like having the option of adjusting the advance. I have the standard Tune but you can also get the Tune+ if you want to create your own ignition advance curve.
#4 Post by tony » Sun Sep 02, 2018 6:36 pm
Nothing wrong with the Pertronix unit. Have fitted them to all my Triumphs and a big improvement on points and condenser.
#5 Post by Charles H » Sun Sep 02, 2018 11:00 pm
I think the Pertronix is the same as Aldon. The Aldon is a great bit of kit. All my Triumphs have them. I did try a much cheaper Simon BBC one once. The early cars rev counter does not work with it! Aldon would be my advice.
#6 Post by Clifford Pope » Mon Sep 03, 2018 8:38 am
I must try again with Petronix. I had a frustrating experience trying to fit it a few years ago. It seemed as if I'd been sold the wrong kit - the timing was about 30 degrees out, and non-adjustable. The fixing hole in the plate was in the wrong place, and I gave up trying to work out where it should be.
A final annoyance was that the instructions said that if the rotating bit was rubbing on the pick-up, or closer than about 25thou, the hole should be elongated to increase the gap. When I sent the kit back to say it appeared to be the wrong one they refused a refund because I had followed this advice and modified the hole.
I got the kit back again but have never tried to see if I can make it work. It hardly seems worthwhile now the standard points are working well.
Ltriumph
#7 Post by Ltriumph » Tue Sep 04, 2018 2:35 am
A mechanic has suggested a 'drop in' as opposed to a kit, if that makes sense. Can anyone suggest a brand for that. I noticed there is a Chinese brand called Sherryberg that has one available but a bit nervous about putting an unknown brand in my car.
#8 Post by Dave B » Tue Sep 04, 2018 5:32 pm
https://www.classicheads.com/Electronic-Ignition/
Both my Triumphs have been fitted with a kit from these guys, and have never missed a beat in over 10 yrs in the blue car, and over 15 yrs in the red car. I have never had to adjust anything once they were set up, they have been completely reliable, I would never go back to points and condenser. All the "gubbins" of the kit are under the dizzy cap, so a cursory glance under the bonnet everything looks standard. I have also bypassed the ballast resistor and fitted a 12v coil, along with a modern 'red' rotor arm.
torque2me
#9 Post by torque2me » Fri Sep 21, 2018 7:03 pm
Issue summons in the Small Claims Court and see if that doesn't get their interest.
Hint: Companies cannot represent themselves in court and thus they will need the service of a Barrister. What do they charge of a 1/2 day? A no brainer. Of course it all depends on how much you want one's nose put out simply to bring that company to heel!
