Oil to use
Ltriumph
Oil to use
#1 Post by Ltriumph » Thu Mar 08, 2018 7:20 pm
I have a discussion going on with a mechanic that does some work on my car. I purchased Penrite HPR 30 20W - 60, he said I should have purchased a 20W - 50, is the Penrite wrong for the car?
Triumph TC 2000 1978
Triumph Bonneville T120 2018
valencia
Re: Oil to use
#2 Post by valencia » Thu Mar 08, 2018 10:42 pm
I suppose 20-50 was the original spec oil but I cannot see a problem with the oil you have purchased, I don't recall 20-60 being available anyway when our cars were current models, I imagine you just have an oil that at a higher temperature will still retain the correct viscosity compared to the 20-50, of course both oils will perform the same at low temperatures.
Hope this helps,
Re: Oil to use
#3 Post by tony » Fri Mar 09, 2018 2:19 am
I've used {use} 20/60 in my 2500.Seems to hold better oil pressure when hot.
1976 2500 TC.
2003 BMW 525i Touring.
Hopefully don't need bits !
Re: Oil to use
#4 Post by Mike Stevens » Sun Mar 11, 2018 10:03 pm
Oh dear. I replied to the other instance of this question! Not that I said anything different to what's already been said here.
