Hi guys
Newbe here. My 2500 has a distinct vibration at 4000 RPM (vehicle stationary and in neutral). My novice diagnosis is the harmonic balancer. Any opinions as to this diagnosis ?
Can anyone point me to a parts supplier who may stock this pulley ?
Thanking you in advance...
Regards
Mudder
Harmonic Balancer crank pulley ?
Re: Harmonic Balancer crank pulley ?
Probably a silly question but why are you revving it to 4000 when stationary
It can be the clutch and flywheel assembly. Crankshaft pulleys are available from many sources including second hand. Try Chris Witor perhaps.
To eliminate the drive train...tony wrote:Probably a silly question but why are you revving it to 4000 when stationary
Thanks - will look them up...Charles H wrote:It can be the clutch and flywheel assembly. Crankshaft pulleys are available from many sources including second hand. Try Chris Witor perhaps.
