Oil pressure
Hi started car yesterday ran ok but then after I stopped & then pulled off again the oil light stayed on drove back 100 yards back home no bad noises? Put oil pressure gauge on today still no reading took off oil pressure switch span engine over & no oil came out took off relief valve & all looked OK any ideas ? Tia,
Re: Oil pressure
Had this once. It was the pressure relief valve stuck open. If you have refitted the valve, see if you get an oil supply again. If not, it is starting to point at an oil pump failure which is rare.
Re: Oil pressure
Took off pressure relief valve & spun engine over no oil came out looks like oil pump then? Can you drop sump without taking engine out?
Re: Oil pressure
yes support car on stands and drop the suspension crossmember , pull it down as low as it will go
need to release steering coupling from rack and remove dipstick and look out for any brake pipe clips
and sump is then removable on car.
Pete
Pete
Pete Lewis
Luton
Luton
Re: Oil pressure
check mills pin first, just a thought
Re: Oil pressure
All sorted now thanks ordered new pump & on measuring it against the old one there was 4 mm difference in length of rotor spindle so the old one was just kissing the distributer drive shaft assembly so had a lucky escape engine was ment to be recon? Old pump must be ment for something else? Ps why did triumph fit so many sump bolts?
Re: Oil pressure
Hello T2000,
because the sump is a light pressing with a flimsy flange.
Re: Oil pressure
Over the years several times I saw these differences in spindle length, also with the 4 cylinders. Often 1/4". So beware. Always measure.
Very nice and true remark about the flimsy flange..
Onno Zijlstra
