Hi all,
Well, that was a busy day... The engine and gearbox are out, whilst I and my gallant mate are thoroughly knackered...
After all my fretting, the gearstick was actually really easy to extract, although someone had obviously been there before and the little anti-rattle spring and plunger are long gone whilst the gaiter is split (although I note that CW is having these remade).
Getting the clutch slave cylinder bracket off the engine back plate was a pain, since someone had reversed one of the fixings (I’m guessing during a clutch change) and we ended up having to take the sump pan off to get the bolt out!
If anyone out there is contemplating similar major surgery on their Big Six, I recommend three essential bits of kit:
- Heavy duty, high lift trolley jack: much better than faffing around with a small jack and wooden blocks! I had previously procured via eBay some seriously beefy axle stands, so felt really safe working under the car.
- Cordless impact wrench: probably the best money I’ve ever spent on garage kit. It made the job SO much easier than using hand ratchets. Of course, on reassembly, I’ll use a torque wrench to properly check fixings
- Thick foam mat: made scrabbling under the car comfortable and I ache less today than I'd expected to!
Thank you all for your advice
