Electric fan installation
Re: Electric fan installation
#11 Post by Clifford Pope » Fri Jan 24, 2014 6:32 pm
Polly wrote:I'm with Alex on this one, since a fan must first suck in air before it can then blow it out at the other side, it will be irrelevant which side of the radiator it is mounted.
I agree, unless you are fitting the fan to a car that has a shroud to funnel the air past the fan. In that case obviously a funnel won't funnel backwards.
I have a Mark 1 with the fan in front of the radiator. I did have to make a small cut-out slice from the cross-panel under the radiator, to clear the fan surround. Probably that would have been unnecessary with a slightly smaller fan.
I haven't noticed any loss of efficiency from that position, it easily maintains the correct temperature, only ever cutting in in slow traffic or a very hot day climbing a hill.
I agree a relay is a good idea to isolate the warning light. On another vehicle the light used to glow so brightly it was pointless as an indicator that the fan had cut in.
#12 Post by Alan Chatterton » Fri Jan 24, 2014 7:40 pm
So, if I fit a fan between the grill and the radiator (ie not engine side of rad) should I use a blow or suck one?
Richard B
#13 Post by Richard B » Fri Jan 24, 2014 9:05 pm
:lol: :lol: 8)
I got confused about this to, but;
The curved bladed fans with the surrounding ring work more efficiently when rotating in one direction than the other.
Fit it in the engine bay and you want it to suck the air through the radiator.
Fit it to the other side and if you do not change anything else, it will still suck through the radiator; but from the engine bay out through the grill. When the car is stationary this would be fine, however if the car is moving then the air flow will reduce or stall.
So if the fan is fitted to the front, you have to reverse the polarity of the motor to push the air. With a curved blade it does not move as much air when in reverse compared to the normal direction of rotation.
To give an example "Airflow rating: Pull = 1250cfm / Push = 1065cfm "
http://www.ebay.co.uk/itm/Stoney-Racing ... 944805794?
Richard
Compulsive PI'er :)
oh, and bought a TR250
David Withers
#14 Post by David Withers » Fri Jan 24, 2014 10:53 pm
There are two distinct types of fan geometry, depending on whether the fan is to pull or push the air through the radiator. The BMC Morris 1100 car, for example, had a 'pusher' fan whereas the normal fan on our Triumphs is the 'puller' type.
#15 Post by Alec » Sat Jan 25, 2014 9:04 am
Hello Richard,
Kenlowe fans are either pushers or pullers, i.e. designed to suit the location. Obviously if 'robbing' fans from another vehicle the correct location must be chosen as fitted to the original donor vehicle.
leesellars
#16 Post by leesellars » Sat Jan 25, 2014 5:39 pm
Blow in front of Rad
Suck Behind Rad
Simples
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
Richard B
#17 Post by Richard B » Sat Jan 25, 2014 6:17 pm
Alec wrote:Kenlowe fans are either pushers or pullers, i.e. designed to suit the location.
Hi Alec, agreed, but I did not buy one from Kenlowe.
So back to my original question. Has anyone fitted one behind the radiator and if so what make and size was it? :?:
Richard
Compulsive PI'er :)
leesellars
#18 Post by leesellars » Sat Jan 25, 2014 6:36 pm
Richard
Heve you got PAS. If so you wont get one in the engine bay. So you will have to Put one infront of the Rad. 14" blower from revotek £75.00 ish. Then you will need a Relay, fan switch in the Rad and a Bypass switch. Simples
lee
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
Richard B
#19 Post by Richard B » Sat Jan 25, 2014 11:51 pm
Ah yes 2000 MkII Estate with PAS. All fitted and wired up, as I said has a double Make relay, that disconnects the warning light from the motor when switched off.
Manual override and an 88-93 switch fitted to the top of the radiator. I'll fit a lower one if it runs too hot.
Still theres hope for my PI then as that is not PAS.
Richard
Compulsive PI'er :)
#20 Post by Alec » Sun Jan 26, 2014 8:40 am
Hello Richard,
I take it you are still not convinced that fitting the fan before the radiator is an effective location?
I would point out that the flow figures you quote earlier are not a good example. The fan may be reversible direction but to get the best when pushing the blade would need to be removed and reversed on the motor spindle, this would give the higher airflow figure when pushing. I note from the illustration that it is very similar to the current Kenlowe fan design which I have.
Users browsing this forum: No registered users and 16 guests
