It is currently Tue Sep 07, 2010 10:56 pm
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: Rocker Shafts
PostPosted: Wed Feb 10, 2010 10:10 am
Offline
On the one occasion I removed the overhang, I didn't have a bench grinder so I used a coarse/fine carborundum stone. A long job but it did have the advantage of being easier to control.
Top
 Profile
PostPosted: Wed Feb 10, 2010 10:31 am
Offline
Hello David,
you middle name is not Job by any chance? :-)
_________________
Top
 Profile
PostPosted: Wed Feb 10, 2010 9:56 pm
Offline
Hello Alec,
It was many years ago, on my Mk1, and the indentations may not have been too deep. It worked anyway, so I was happy.
David.
Top
 Profile
PostPosted: Wed Feb 10, 2010 11:13 pm
Offline
New rocker assembly fitted this evening, lovely!!
Makes a nice whirring sound now instead of the old clatter and it seems to run better now that the valves are opening fully. It's even better if you remember to re-fit the vacuum advance pipe..............
I got sidetracked by beer so a final check and adjust tomorrow and it's back on the road. :)
It's impossible to judge the hardness of the components, the proof of that will be in their durability but the standard of machining etc. looked fine.
Top
 Profile
PostPosted: Thu Feb 11, 2010 12:08 pm
Offline
Yes .... grinding away the sides of the rocker tip would be a race modification, and I would reassemble the rockers in the same order. Mark them 1-12 with a Pental correcting pen. For general reconditioning I would say carefully grind the face, either side around where the valve has indented, not touching the actual rubbing surface. This will enable to measure accurate gaps. It would be essential if fitting a new shaft as each rocker tip usually has a very slightly different contact area, so may need a wider tip - any indent would be a problem.
_________________
Steve Knight
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
