LeJog in a Triumph
Any Triumph related event taking place
LeJog in a Triumph
#1 Post by Charles H » Thu Sep 29, 2016 2:59 pm
I have again entered the Lands End to John O'Groats Rally in my Mk1 rally car. It takes place on the first weekend of December and is known as the hardest rally in Europe! The car and I have done this event twice before, the last in 2011 where we achieved a Gold Medal, one of only two! This year I have Richard Lambley as my navigator, but first I need to repair the car, 'cos we broke it last weekend doing a night rally on the Romney Marsh. The inner and outer wings have sort of split......oops! I also have an annoying high rev misfire to cure before we set off. The details of the event can be found at http://www.heroevents.eu/Events/lejog/
Pimento Red Stag
CAR
Re: LeJog in a Triumph
#2 Post by CAR » Fri Sep 30, 2016 10:32 am
Charles H wrote: The inner and outer wings have sort of split......oops!
Split?
Parted company or worse, do you have any pics Charles?
That sounds very bad.
#3 Post by Charles H » Fri Sep 30, 2016 2:27 pm
Will get Phil to help me put up a photo. He is back on Saturday. I'm not clever enough!! :oops: The inner and outer have separated by nearly an inch. More independent suspension than it was designed with!
Pimento Red Stag
#4 Post by Charles H » Sun Oct 02, 2016 1:14 pm
This is the problem. The first image shows the outer bowl pulled away from the inner. The underseal has not come off, it has pulled that distance apart.
The second two show that the inner arch has not only pulled in, but moved up slightly. Hopefully it will all move back into position and be re-attached and seam welded up.
Pimento Red Stag
#5 Post by Charles H » Sat Nov 19, 2016 12:34 pm
Car now welded back together successfully. Also seam welded the other side as well as a precaution. Preparation well under way and due a 12 car shakedown tomorrow morning to try and iron out any gremlins.
In two weeks time we will be under way in the South West on our long haul north. Can't wait. We are in a class with an Alfa Giulia Sprint, an Alfa GTV and a Mk1 Lotus Cortina. Details and updates on the website http://heroevents.eu/event-type/le-jog/
Pimento Red Stag
#6 Post by Mike Stevens » Sun Nov 20, 2016 11:20 am
Good luck Charles. I hope it all goes to plan! (And you win of course!)
#7 Post by Charles H » Sun Nov 20, 2016 5:20 pm
Thanks Mike.
The 12 car shakedown has been successfully completed with a 3rd over all. The car behaved well and subject to a check during the week, only needs the wheels and tyres changing for the winter set, the rear brakes adjusting up and undersealing the rear arches. I am sure some cleaning and double checking of everything will keep me busy prior to the journey to Lands End on Thursday week.
Pimento Red Stag
#8 Post by Charles H » Tue Nov 22, 2016 5:27 pm
Undersealing complete, rear brakes adjusted up and winter wheels and tyres bolted on. Just about ready for the off next week.
Pimento Red Stag
LeJog in a Triumph
#9 Post by Alan Chatterton » Tue Nov 22, 2016 8:00 pm
Best of luck Charles!! But, I'm here if you need another calliper couriering out to you again!!!
#10 Post by Charles H » Wed Nov 23, 2016 3:55 pm
Carrying a pair with me now!!!!! Hopefully will not break anything too critical! I still have the towel you supplied wrapping the caliper up in in the car!
That was the most expensive borrowed caliper in the world! Cost me £400 carriage :cry:
Pimento Red Stag
