Eyeball vent feeder hose
A group for the sourcing or production of difficult to obtain or unobtainable parts
Phil T
#1 Post by Phil T » Mon Jul 29, 2019 7:57 pm
Does anyone know where I can get the hose from the heater to the drivers eyeball vent?
1974 Triumph 2000
Re: Eyeball vent feeder hose
#2 Post by johnnydog » Tue Jul 30, 2019 8:30 am
I no doubt will have a good used one.
I will check today and get back to you.
Do you know the approximate length (just in case I haven't labelled the ones I have?)
Phil T
#3 Post by Phil T » Tue Jul 30, 2019 9:26 am
Thanks Johnnydog.
No idea of the length, will try and get out to measure tomorrow (peeing down today).
I assume it runs behind the instruments and not over..........
#4 Post by johnnydog » Tue Jul 30, 2019 12:46 pm
Yes, I have one.
I have sent you a pm.
John
#5 Post by johnnydog » Wed Jul 31, 2019 10:07 am
One hose and wire hose clip posted this morning Phil.
John
Phil T
#6 Post by Phil T » Mon Aug 26, 2019 7:02 pm
Many thanks John, now all fitted and functional.
#7 Post by johnnydog » Tue Aug 27, 2019 9:53 am
Phil T
#8 Post by Phil T » Fri Aug 30, 2019 9:45 am
I even managed to reconnect the speedo drive (virtually) first time and it is working! Not a job I like as there is little play in the cable and requires a bit of wrist acrobatics.
(When I got the car is was not properly connected and slipping, underreading the speed.)
#9 Post by johnnydog » Fri Aug 30, 2019 1:28 pm
I sometimes find it easier to disconnect the speedo cable at the gearbox end, and then feed it up a couple of inches through the hole in the transmission tunnel, connect it at the top with the extra cable available, and then pull it back down to reconnect it at the gearbox. This also avoids any damage to the speedo wood surround (which you tend to rest on top of the steering column binnacle) whilst fighting to connect the piece at the top.
It is also sometimes held in place by the metal tabs on the bodywork, which when released give a bit if extra free play.
