Mk1 PFL Estate
The head is no fitted, water pump fitted, manifolds test fitted, no sign of any interference, will fully fit them tomorrow. Awaiting return of the fuel pump so I can progress the fuelling system.
Re: Mk1 PFL Estate
Today I fitted the rocker shaft & adjusted the tappets, then I moved to the rear of the car and removed the fuel tank. With my car being a PFL model, it had a smaller tank than the later estates, I wanted to fit the later tank. In order to get the larger tank in, I had to remove the O/S floor support bar, this will be replaced by a removable bar, I also had to remove the inboard support bracket, this will be replaced by another bracket further along the axle tunnel. Unfortunately my limited testing of this tank didn't spot a slight weep, I will have to remove it and get the tank repaired, at least I have proved that it is a viable solution, the spare tyre fits fine and won't interfere with the Lucas Pump, PRV or filter (latter isn't fitted in pic, will be mounted higher up)
Re: Mk1 PFL Estate
Cutting a long story short, I now have a running 2.5PI setup in my Mk1 2000 Estate. The car isn't roadworthy yet, there are a few things I still need to address, I want to fit copper fuel lines, I am not happy with the nylon pipe running close to the exhaust. The PAS pipes are weeping, will try putting some sealant on the threads. I need to fit Mk2 throttle pedal and bleed brakes. The car still has 4:11 diff fitted, acceleration should be brisk, phase two of this work sees a 3:45 diff & CV shafts being fitted.
https://youtube.com/shorts/qgQfA0GGx6Q?feature=share
Re: Mk1 PFL Estate
After what feels like a long time, the Estate drove out of my garage as a 2.5 PI car, it’s not running quite right yet but the major work is done.
Re: Mk1 PFL Estate
Great news
