Mk1 2000 mo/d saloon.
top draw laurence, looks stunning !!!!!!!
- Jonathan Lewis
Re: Mk1 2000 mo/d saloon.
Indeed - lovely job Congratulations!Lloydpiestate wrote:top draw laurence, looks stunning !!!!!!!
Laurence, it looks like you're going to have an awful lot of fun terrorising motorists down there in the South West with your mean machine! It'll be nice to howl past 'em, especially those boring M-B drivers*
What was the engine spec in the end?
* just seeing if Mr Chairman is paying attention
Obviously not!JimB wrote:* just seeing if Mr Chairman is paying attention
Nice looking machine there.
Having seen the car in the flesh at various stages I can confirm that the photos do not lie, it is a very nice car.
I am paying attention, just rising above it with usual MB driver's aloofness!!
Thanks for the positive comments, looking forward to bedding the engine in a bit more, will be going on the rolling road soon..
Inevitably there are a number of snagging issues, one in particular is a loose boot lid mechanism, not sure how it can tightened , any ideas would be appreciated,
cheers,
Laurence
cheers,
Laurence
The snagging process has continued over the past month or so. One of the main issues has been rust/muck particles being drawn into the filter and ultimately block,i'm sure others have had this problem when recommissioning a car that has been laid up for a long time. A bigger filter has helped and the debris coming through is now very little, hopefully most of its out. The dash fuel indicator has not worked since the return home, not sure whether it is a fuel sender issue or the dash instrument,-any ideas?.
The steering rack was found to be worn and has now been replaced with a CW'quick rack', i believe from a spitfire.A quieter mid exhaust section has been fitted to reduce boom at higher speeds, still sounds great at higher revs with the cherry bomb back box. Hopefully some photos areattached,
cheers,
Laurence
cheers,
Laurence
Nice one mate
Looks superb!!!!
Re the fuel indicator....... is the temp gauge reading ok? if not voltage stabiliser.
If ok fuel sender gauge in tank as you suggest or bad earth...........
Looks superb!!!!
Look forward to seeing the car in its finished state Lawrence,looks great!.
Best wishes.
Bill.
Best wishes.
Bill.
jan and bill radford.
