Project Pi
Re: Project Pi
#41 Post by johnnydog » Mon Jan 14, 2019 5:35 pm
Must be great Ross working with perfectly clean components and underbody structure, rather than with the usual dirt / oil / underseal that you usually encounter on the underbody of the majority of our cars!
Tinsmith_Skippy
Re: Project Pi
#42 Post by Tinsmith_Skippy » Wed Jan 23, 2019 12:15 am
Hello John Im considering buying shares in the Gunk degreaser company.
Last edited by Tinsmith_Skippy on Mon Apr 15, 2019 2:29 pm, edited 3 times in total.
Ross Taylor & Paul Taylor
Member: 7644 & 7644A
Tinsmith_Skippy
Re: Project Pi
#43 Post by Tinsmith_Skippy » Tue Feb 05, 2019 11:46 am
Weekend Update Fitting the Dashboard.
Project Progress:
  • Interior Assembly
  • Epoxy applied inside the doors.
Last edited by Tinsmith_Skippy on Sun Jun 09, 2019 9:39 pm, edited 6 times in total.
Re: Project Pi
#44 Post by Charles H » Wed Feb 06, 2019 12:46 pm
I wish my PI was half as good as this!
Pimento Red Stag
Tinsmith_Skippy
Re: Project Pi
#45 Post by Tinsmith_Skippy » Thu Feb 07, 2019 3:08 pm
Finally seeing the light at the end of the tunnel Charles, 6 years work so far and probably another 4 weeks away to completion. :D
Project Progress:
  • Engine & Front Suspension
Last edited by Tinsmith_Skippy on Sun Jun 09, 2019 9:44 pm, edited 4 times in total.
Re: Project Pi
#46 Post by Charles H » Fri Feb 08, 2019 10:08 am
Makes it look easy! My PI one is on, but slightly adrift at the top (has been for years and years) but will be staying like that. The rally car does not have it fitted. After much swearing, and it coming adrift so it beat the roof, it got ripped off! Must have spent 10 man hours on each. To do it again, I would now need new rubbers anyway!
Pimento Red Stag
Tinsmith_Skippy
Re: Project Pi
#47 Post by Tinsmith_Skippy » Fri Feb 08, 2019 11:28 am
I must admit this worked better with a another set of hands. The Valencia car is going to have a little re adjustment on one corner, couldn’t quite get it to sit right installing it on my own but going to have another try.
But the window rubbers are good for patterns 2 fitted now pleased.
Project Progress:
Last edited by Tinsmith_Skippy on Sun Jun 09, 2019 9:46 pm, edited 2 times in total.
Re: Project Pi
#48 Post by Mike Stevens » Fri Feb 08, 2019 12:42 pm
I can see you getting asked to help fitting some trims or even to give a master-class Ross!
Fancy a trip to South Oxfordshire? :wink:
Tinsmith_Skippy
Re: Project Pi
#49 Post by Tinsmith_Skippy » Tue Apr 30, 2019 6:52 pm
On the final push to completion!
White walls get in!
A tool for every job.
Bleeding the injectors.
Tinsmith_Skippy
Re: Project Pi
#50 Post by Tinsmith_Skippy » Tue Apr 30, 2019 6:58 pm
Rear finally coming together.
Next project tool idea
Bored at work so a little modelling in lunch breaks.
